On diagonal rod length February 09, 2014 12:37AM |
Re: On diagonal rod length February 10, 2014 07:27AM |
Re: On diagonal rod length February 10, 2014 01:06PM |
Re: On diagonal rod length February 10, 2014 03:22PM |
hercek
You can select your diagonal rods whatever length you like, but:
The longer rods you select the more far away from the center you will be able to print (at the locations where towers are not in the way).
- If you want to reach with your platform to the tower base (so that the corresponding diagonal rod is vertical) then you need your rods to be longer than sqrt(3) * deltaRadius. If you select the diagonal rod length just at this low boundary then you will be barely able to print behind the triangle defined by the towers.
- If you want your built area to cover a full circle with radius deltaRadius then you need your diagonal rod long at least 2 * deltaRadius.
The longer rods you select the lower your print area height will be.
Re: On diagonal rod length February 10, 2014 04:22PM |
Correct. It is also computed as towerOffset - effectorOffset - carriageOffset.Quote
epicepee
DeltaRadius is the horizontal distance that the carbon rods span when the effector is centered, correct?
I do not know what radius of reuleaux triangle means. Also it would not be reuleaux triangle any more since:Quote
epicepee
If so, it seems to me that having rods twice as long as deltaRadius would trace a reuleaux triangle with a minimum radius of deltaRadius,
Correct.Quote
epicepee
... and having rods sqrt(3) times deltaRadius would give you a reuleaux triangle with the corners just touching the towers.
Re: On diagonal rod length February 10, 2014 04:25PM |
Re: On diagonal rod length February 10, 2014 04:54PM |
I did not investigate how precision changes around built area. But around all the available built area it will by always about the same as your stepper motor single step length. The only thing which will change is how one carriage position error will distribute into hotend tip cartesian X/Y/Z errors.Quote
epicepee
Okay, that makes sense. How much of a precision hit do I take by making the rods longer?
I do not know. Depends on the exact design of the probe. Check some videos to see how much you need to move when deploying/retracting probe.Quote
epicepee
Also, am I correct in saying that I need to be able to move outside the build volume in order to retract the bed probe?
