Kossel Calibration Problem February 24, 2014 10:20AM |
Re: Kossel Calibration Problem February 26, 2014 07:42AM |
Re: Kossel Calibration Problem February 28, 2014 08:06AM |
Re: Kossel Calibration Problem March 02, 2014 01:17PM |
Re: Kossel Calibration Problem November 03, 2015 07:59AM |
Re: Kossel Calibration Problem November 03, 2015 08:07AM |
maciek117
Anyone found a solution? I have the same problem and i can't get trough it. I have changed manual home pos as well as the probe offset but nothing works for me.
The only solution i came up with is G92 Z4.7 command which changes Z0 to Z4.7 and it's not very elegant.
Anonymous User
Re: Kossel Calibration Problem November 03, 2015 09:24AM |
Re: Kossel Calibration Problem November 03, 2015 12:30PM |
Sir_Death
Threw the z-Probe away, after it engraved the Heatbed. (Self-Deploying while printing...)
Did an extra round on manual calibration --> perfect. (Deviation of heatbed <0,0... --> smaller than I can measure...)
If - somewhere in the future - object does not stick to heatbed anymore, I will recalibrate...
Anonymous User
Re: Kossel Calibration Problem November 04, 2015 03:08AM |
Re: Kossel Calibration Problem November 04, 2015 04:01AM |
xile6
Sir_Death
what method did you use to calibrate the printer?
i hear of people doing it without a probe i just dont see how it can get everything.
Anonymous User
Re: Kossel Calibration Problem November 04, 2015 04:49AM |
Koenig
Not that much to get assuming you have a flat bed that is perpendicular to the towers + having some clue as to how long your rods are (can be calibrated rather precisely later).
Z-height, endstop ajdustments and delta radius.
If your build is not so correct then you might want to add angles or/and tower offsets.
Re: Kossel Calibration Problem November 04, 2015 05:07AM |
Sir_Death
Koenig
For me, this is Standard calibration. Z-Probing and/or Papertest are useless, if you did not do Standard calibration.
Re: Kossel Calibration Problem November 04, 2015 06:57AM |
If you are good at math then you can use the paper method with this maxima notebook: [github.com]Quote
xile6
Anonymous User
Re: Kossel Calibration Problem November 04, 2015 07:12AM |
Re: Kossel Calibration Problem November 04, 2015 07:18AM |
