Suggestions to cover up bare extrusions?
May 18, 2014 06:04PM
Hey guys, I want to make my delta have a cleaner look by covering up the bare extrusions. Do you guys have any suggestions on what I should use? MDF? Metal panels? etc? Thanks.
Re: Suggestions to cover up bare extrusions?
May 19, 2014 12:14AM
I plan to buy some acrylic glass sheets to make an enclosure for my (planned) kossel mini, and print holders that extrude from the extruders, and cover them up as well as hold the glass plates. Not sure how this will work out though. They should be really light weight. I also want to make an air extraction to avoid micro particles and/or fumes (although I've heard that good ABS doesn't smell at all). But really the only solution is to print out the coverings and cover the coverings with some awesome carvings. Maybe you can even make them "clip on" to the extruders?
Edited 1 time(s). Last edit at 05/19/2014 12:15AM by Dejay.
May 20, 2014 08:09AM
maybe my build can give you some idea...
it's all metal build, very, very simple and rigid as a rockwinking smiley
I still can not give you too much information. All I'll say is that I'm working on Delta Mini project and that everything will be OpenSource under the GPL-license and it I'll be very well documented ...
so stay tune...
May 20, 2014 08:33AM
Very pretty!
May 20, 2014 11:59AM
That looks amazing! Keep us updated!
