Original Rostock issue(s) May 27, 2014 07:54AM |
Re: Original Rostock issue(s) May 27, 2014 08:21AM |
Re: Original Rostock issue(s) May 27, 2014 08:28AM |
Re: Original Rostock issue(s) May 27, 2014 08:51AM |
Re: Original Rostock issue(s) May 27, 2014 09:08AM |
Re: Original Rostock issue(s) May 27, 2014 09:23AM |
Re: Original Rostock issue(s) May 27, 2014 09:45AM |
// Travel limits after homing #define X_MAX_POS 90 #define X_MIN_POS -90 #define Y_MAX_POS 90 #define Y_MIN_POS -90 #define Z_MAX_POS MANUAL_Z_HOME_POS #define Z_MIN_POS 0
// Travel limits after homing #define X_MAX_POS 90 #define X_MIN_POS -90 #define Y_MAX_POS 90 #define Y_MIN_POS -90 #define Z_MAX_POS 170 #define Z_MIN_POS 0================================================
#define MANUAL_HOME_POSITIONS // MANUAL_*_HOME_POS below will be used // For deltabots this means top and center of the cartesian print volume. #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 170 // For delta: Distance between nozzle and print surface after homing.
Re: Original Rostock issue(s) May 27, 2014 10:07AM |
Re: Original Rostock issue(s) May 27, 2014 10:24AM |
Re: Original Rostock issue(s) May 27, 2014 03:45PM |
//#define MANUAL_HOME_POSITIONS // MANUAL_*_HOME_POS below will be used // For deltabots this means top and center of the cartesian print volume. #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 100 // For delta: Distance between nozzle and print surface after homing.
X:0.00 Y:0.00 Z:70.00 E:0.00 Count X: 287.08 Y:287.08 Z:287.08
Re: Original Rostock issue(s) May 27, 2014 03:49PM |
//#define MANUAL_HOME_POSITIONS // MANUAL_*_HOME_POS below will be used // For deltabots this means top and center of the cartesian print volume. #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 50 // For delta: Distance between nozzle and print surface after homing.
SENDING:M114 X:0.00 Y:0.00 Z:20.00 E:0.00 Count X: 237.08 Y:237.08 Z:237.08
Re: Original Rostock issue(s) May 27, 2014 06:12PM |
