Cherry Pi III Is Available May 27, 2014 12:48PM |
Re: Cherry Pi III Is Available May 27, 2014 07:30PM |
Re: Cherry Pi III Is Available May 28, 2014 03:05AM |
Re: Cherry Pi III Is Available May 28, 2014 03:53AM |
Re: Cherry Pi III Is Available May 28, 2014 05:57AM |
Artlav
Nice design, if not for the bolt heads you need to drill to fit the magnets.
Are there any alternatives to them, for magnetic coupling?
Re: Cherry Pi III Is Available May 28, 2014 07:36PM |
Re: Cherry Pi III Is Available May 29, 2014 02:43AM |
Re: Cherry Pi III Is Available May 29, 2014 07:30AM |
Re: Cherry Pi III Is Available May 29, 2014 08:04AM |
Re: Cherry Pi III Is Available June 02, 2014 05:00PM |
Glad I didnt print already!|
Re: Cherry Pi III Is Available June 02, 2014 07:01PM |
Re: Cherry Pi III Is Available June 03, 2014 09:22AM |
Re: Cherry Pi III Is Available June 04, 2014 11:50AM |
Re: Cherry Pi III Is Available June 04, 2014 03:25PM |
Re: Cherry Pi III Is Available June 04, 2014 03:36PM |
Re: Cherry Pi III Is Available June 04, 2014 05:51PM |
nka
Andy,
What firmware do you use into the RAMPS? Marlin?
Also, I would like to add a 25mm (I took the mesurement of the Sunon MC25101V1000UA99) fan for the J-Head as it seems recommended for PLA. I would hook it only on the bottom (red arrow) ?
(SketchUp : [stuff.quebecit.net] )
Does it make sens to you?
I'm asking cause, since I dont have the printer yet, it's hard for me to figure how it will fit. Plus, it will be printed in ABS and I wont be able to do it with the printer.
Or something like this, were I could "clip" the fan?
Re: Cherry Pi III Is Available June 04, 2014 06:02PM |
WZ9V
I'm curious as to how you machined the bolt heads with the ball head mill.
I was looking at magnetic arms for a MK but they used cylinder magnets in the arms with steel balls on the effector and carriage.
Your way seems cleaner to me since it seems like it would have more surface area for the the attraction between the parts and be easier to assemble. I have a feeling my MK will be busy making parts for one of these once I get it going. I wanted to scale up to a 250mm build surface and 2020 extrusions anyway. Would the Misumi 2020 be an adequate substitute for the Bosch/Rexroth extrusions? I already have some 360mm and 750mm handy.
Re: Cherry Pi III Is Available June 04, 2014 06:03PM |
nka
Re: Cherry Pi III Is Available June 04, 2014 06:15PM |
WZ9V
I put the M5 SHCS's into the rods, held the rods in front of the drill, and pushed by hand until they were milled to a cup. Since I used black screws, it was easy to see how deep that I was cutting since the cup was shiny metal and the remaining cap was black. Just keep milling until the silver reaches the edge of the head, and that's it. There's no reason to mill any deeper. I did 24 screws on one 18V battery charge with energy to spare.....
Re: Cherry Pi III Is Available June 04, 2014 08:18PM |
Re: Cherry Pi III Is Available June 04, 2014 09:23PM |
Re: Cherry Pi III Is Available June 04, 2014 09:55PM |
Re: Cherry Pi III Is Available June 05, 2014 07:02AM |
Re: Cherry Pi III Is Available June 05, 2014 09:04AM |
Re: Cherry Pi III Is Available June 05, 2014 11:21AM |
Re: Cherry Pi III Is Available June 06, 2014 12:25PM |
Re: Cherry Pi III Is Available June 07, 2014 07:27PM |
Re: Cherry Pi III Is Available June 07, 2014 10:02PM |
AndyCart
vreihen
For once, I may be ahead of you! I'm half way through printing the CP-I rod holders and effector plate, and plan to use some leftover 5/16" steel spheres from my Johann recirculating ball bearing carriage experiment to ride in the 10mm cups. I think that shock cord is the way to go, but we'll see once I have the last two rod holders printed.....
Pictures please :-)
Re: Cherry Pi III Is Available June 08, 2014 06:21PM |
Re: Cherry Pi III Is Available June 08, 2014 07:55PM |
AndyCart
Oh well. It's fun trying new things. Like you I've decided it' easier to just buy the magnets. Currently I'm getting them as a block of 64 from China for about £16. They are marketed as an executive toy but they are just 10mm neodymium spheres so perfect for our needs.
AndyCart
Core XY kinematics has me hooked at the moment. Very promising in terms of print quality and speed.
