Glass tower delta August 06, 2014 07:45AM |
Re: Glass tower delta August 06, 2014 09:40AM |
Re: Glass tower delta August 06, 2014 09:54AM |
Re: Glass tower delta August 06, 2014 11:23AM |
rsenas
the weight of this structure and the quality of parts made stands compared to its previous. Hugs.
Re: Glass tower delta August 06, 2014 11:40AM |
Wildcard
Looks nice! I enclosed my printer in a case made of Lexan and wood. It doesn't add much weight, but to make the entire setup more stable, it is all attached to a table via bolts. Is yours attached via bolts to the table? If it is not attached to the table do the weights keep it stable, or if it is attached to the table are the weights used just to counteract any rocking that occurs? A question that I have is during higher print speeds do the weights sway? Another cool addition you may want to experiment with is an air scrubber made out of charcoal equipped with a fan. I put one in mine to get rid of the smell. When I print, I cannot smell anything.
For heaters, I got myself 2 electronics space heaters and four 50w load resistors. My plan was to have them be inside of the heat chamber, but if I ever get around to rigging them up, they will be in a separate box with fans blowing the hot air into the the box on 3 sides for uniform heating. I control the temp with a simple temperature controlled that has a probe on it.
Here's a link to mine:
[thefabforums.com]
Re: Glass tower delta August 06, 2014 11:24PM |
Re: Glass tower delta August 08, 2014 07:36AM |
Re: Glass tower delta October 20, 2014 05:03AM |
Re: Glass tower delta October 20, 2014 06:52AM |
ekaggrat
@Xabbax
what is the size of the springs used between the rods ( diameter , wire diameter , length ) i am experimenting with a similar system on my 3dr and just nned to know what is a STRONG spring?
thanks
