highest reasonable print speedsm December 08, 2014 06:17PM |
Re: highest reasonable print speedsm December 09, 2014 06:18AM |
Re: highest reasonable print speedsm December 09, 2014 08:06AM |
Re: highest reasonable print speedsm December 09, 2014 01:28PM |
Re: highest reasonable print speedsm December 09, 2014 06:55PM |
Re: highest reasonable print speedsm December 11, 2014 02:29AM |
Re: highest reasonable print speedsm December 11, 2014 08:00PM |
Re: highest reasonable print speedsm December 12, 2014 03:37AM |
Re: highest reasonable print speedsm December 12, 2014 02:22PM |
Re: highest reasonable print speedsm December 12, 2014 08:50PM |
shadowphile
I just which it was PTFE all the way to the brass nozzle, then probably no issue.
Re: highest reasonable print speedsm December 13, 2014 01:12AM |
sheepdog43
Don't just crank down on the extruder (sorry, Paul)
It can crush and ovalize the filament, causing it to bind up in the bowden, leading you to further crank it down, and making it worse... It creates a vicious cycle. Keep in mind though that this is much more common 1.75mm filament than 3mm.
