About to buy a delta - would like comments on model before I order April 06, 2015 07:54PM |
(yay!)|
Re: About to buy a delta - would like comments on model before I order April 06, 2015 08:29PM |
Re: About to buy a delta - would like comments on model before I order April 06, 2015 08:30PM |
Re: About to buy a delta - would like comments on model before I order April 06, 2015 08:39PM |
Re: About to buy a delta - would like comments on model before I order April 06, 2015 08:41PM |
mikes3ds
FYI Delta #4 - There is a reason why they are on the outside, you don't want the endstop wire next to your power wire coming off the hotend . It can trigger a false signal to your mirco-controller . That is why you see only one on the outside, cause they probably send the hotend wire down the aluminum tube. =) (You can always re-wire it and send that wire down a different tube)
Re: About to buy a delta - would like comments on model before I order April 06, 2015 08:52PM |
Re: About to buy a delta - would like comments on model before I order April 06, 2015 09:08PM |
Re: About to buy a delta - would like comments on model before I order April 06, 2015 10:41PM |
Re: About to buy a delta - would like comments on model before I order April 06, 2015 10:55PM |
Re: About to buy a delta - would like comments on model before I order April 07, 2015 05:48AM |
Re: About to buy a delta - would like comments on model before I order April 07, 2015 01:40PM |
Re: About to buy a delta - would like comments on model before I order April 09, 2015 08:18AM |
Re: About to buy a delta - would like comments on model before I order April 09, 2015 10:06AM |
J.A.C.
Well, Got my this:
My first printer
It will get me started, I will evolve from there =D
Mow to act indifferent, as if I was not caring when it get's here ... but every time i get home from work, I will carry hope for it to have arrived ... then be a little sad for it not to be there yet!
I will keep up to date on it ^_^
Re: About to buy a delta - would like comments on model before I order April 09, 2015 11:55AM |
LarsK
I once read that you buy one of the brand printers if you want to print things in 3d - And you buy a reprap printer if you want to play with 3d printers - This has been very true.
Re: About to buy a delta - would like comments on model before I order April 09, 2015 05:12PM |
Re: About to buy a delta - would like comments on model before I order April 09, 2015 05:34PM |
AndrewBCN
Having now built a linear delta, I would never recommend a linear delta as a first 3D printer build. Deltas add considerable complexity to the build process and in particular to calibration and firmware settings. Sure enough, because of the lower moving mass of the print head, a delta can usually achieve higher printing speeds, but not higher print quality. They do look cool, though!
Re: About to buy a delta - would like comments on model before I order April 09, 2015 06:49PM |
dc42
AndrewBCN
Having built both a Cartesian printer (Ormerod 1) and a Delta (Mini Kossel), I recommend a delta over a Cartesian. The build process is simpler because you are mostly building the same thing three times. The whole printer is very rigid, so it doesn't go out of alignment as easily. But I did upgrade my Mini Kossel to 32-bit Duet electronics. With modern electronics and firmware and a good Z probe, calibration of a delta is very easy.
Re: About to buy a delta - would like comments on model before I order April 09, 2015 11:09PM |
J.A.C.
Thanks LarsK, we are taking about THIS Printer right?
Have to understand that: when I get it running, if I like the machine, I plan on changing parts, if I do not like 3D printing, I will have wasted 400$ and move on with my life.
If I do Like it, by end of this summer, the machine will be totally changed (except maybe the frame lol ).
But I do want to start with a Delta, I know I am going against everyone on this, but I prefer learning a Delta, (not even getting it for speed) as it is the type of printer i am staying with: less noise, less parts, easier to make wider, less moving parts and my wife thinks it look cool and dose not mind having it in the house.
Re: About to buy a delta - would like comments on model before I order April 10, 2015 04:42AM |
LarsK
@ DC42 - Which one did you build first?
