Marlin 1.02 delta endstops confusion April 12, 2015 04:21AM |
Re: Marlin 1.02 delta endstops confusion April 12, 2015 05:30AM |
Bking1340
Good day all
Have finished building my kossel mini clone. Tested my ramps 1.4 with prusa I3 firmware. With M119, it shows min=open and max=trigerred for all 3 endstops - when I move my cariages up, M119 shows min=triggered and max=triggered. I know it`s the wrong firmware, but my endstop switches seems to work.
Now I load Marlin 1.02 with my modified delta config. Now M119 show only max=open for all 3 endstops which are correct, but when I trigger my endstops, M119 show max=open - so my endstops does not trigger. My endstops are located on the top of each arm and are connected on the outer 2 pins on the endstop switch.
Your help will be appreciated.
My endstop config in Marlin:
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
// #define ENDSTOPPULLUP_XMAX
// #define ENDSTOPPULLUP_YMAX
// #define ENDSTOPPULLUP_ZMAX
// #define ENDSTOPPULLUP_XMIN
// #define ENDSTOPPULLUP_YMIN
// #define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
// Deltas never have min endstops
#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
