Strange rings pattern on my delta May 15, 2015 06:39PM |
Re: Strange rings pattern on my delta May 22, 2015 03:27AM |
Re: Strange rings pattern on my delta May 22, 2015 03:57AM |
Re: Strange rings pattern on my delta May 25, 2015 09:31AM |
Re: Strange rings pattern on my delta May 25, 2015 12:14PM |
Re: Strange rings pattern on my delta May 25, 2015 04:30PM |
roboprint
So, this moire depends on segmentation and speed.
David, can you print such model in your segmentation-free firmware?
OpenSCAD code for model is "cube([50, 50, 50]);"
Re: Strange rings pattern on my delta May 25, 2015 05:52PM |
Re: Strange rings pattern on my delta May 25, 2015 06:40PM |
roboprint
dc42
As it happens, I've just rebuilt my delta to increase the height to 1m and use 2020 extrusions instead of 1515, and I am about to do my first print. So I'll use that cube. Just give me a minute to autocalibate...
Looks like your autocalibration is not as fast as you say
Re: Strange rings pattern on my delta May 25, 2015 06:52PM |
Re: Strange rings pattern on my delta May 26, 2015 03:27AM |
Re: Strange rings pattern on my delta May 26, 2015 03:34AM |
Re: Strange rings pattern on my delta May 26, 2015 03:46AM |
roboprint
This is box top side. Can you show box walls?
Re: Strange rings pattern on my delta May 26, 2015 05:44AM |
Re: Strange rings pattern on my delta May 26, 2015 06:17AM |
Re: Strange rings pattern on my delta May 26, 2015 09:41AM |
Re: Strange rings pattern on my delta May 26, 2015 10:31AM |
; avoid_crossing_perimeters = 1 ; bed_shape = 87.0207x9.14624,85.5879x18.1923,83.2174x27.039,79.9352x35.5895,75.7772x43.75,70.789x51.4312,65.0252x58.5489,58.5489x65.0252,51.4312x70.789,43.75x75.7772,35.5895x79.9352,27.039x83.2174,18.1923x85.5879,9.14624x87.0207,0x87.5,-9.14624x87.0207,-18.1923x85.5879,-27.039x83.2174,-35.5895x79.9352,-43.75x75.7772,-51.4312x70.789,-58.5489x65.0252,-65.0252x58.5489,-70.789x51.4312,-75.7772x43.75,-79.9352x35.5895,-83.2174x27.039,-85.5879x18.1923,-87.0207x9.14624,-87.5x0,-87.0207x-9.14624,-85.5879x-18.1923,-83.2174x-27.039,-79.9352x-35.5895,-75.7772x-43.75,-70.789x-51.4312,-65.0252x-58.5489,-58.5489x-65.0252,-51.4312x-70.789,-43.75x-75.7772,-35.5895x-79.9352,-27.039x-83.2174,-18.1923x-85.5879,-9.14624x-87.0207,0x-87.5,9.14624x-87.0207,18.1923x-85.5879,27.039x-83.2174,35.5895x-79.9352,43.75x-75.7772,51.4312x-70.789,58.5489x-65.0252,65.0252x-58.5489,70.789x-51.4312,75.7772x-43.75,79.9352x-35.5895,83.2174x-27.039,85.5879x-18.1923,87.0207x-9.14624,87.5x0 ; bed_temperature = 65 ; before_layer_gcode = ; bridge_acceleration = 0 ; bridge_fan_speed = 100 ; brim_width = 0 ; complete_objects = 0 ; cooling = 0 ; default_acceleration = 0 ; disable_fan_first_layers = 3 ; duplicate_distance = 6 ; end_gcode = M104 S0 ; turn off temperature\nM140 S0 ; bed temperature\nG28 ; home X axis\nM84 ; disable motors\nM106 S255\n ; extruder_clearance_height = 20 ; extruder_clearance_radius = 20 ; extruder_offset = 0x0 ; extrusion_axis = E ; extrusion_multiplier = 1 ; fan_always_on = 0 ; fan_below_layer_time = 60 ; filament_diameter = 1.75 ; first_layer_acceleration = 0 ; first_layer_bed_temperature = 65 ; first_layer_extrusion_width = 150% ; first_layer_speed = 50% ; first_layer_temperature = 215 ; gcode_arcs = 0 ; gcode_comments = 0 ; gcode_flavor = reprap ; infill_acceleration = 0 ; infill_first = 0 ; layer_gcode = ; max_fan_speed = 100 ; min_fan_speed = 35 ; min_print_speed = 10 ; min_skirt_length = 0 ; notes = ; nozzle_diameter = 0.4 ; only_retract_when_crossing_perimeters = 0 ; ooze_prevention = 0 ; output_filename_format = [input_filename_base].gcode ; perimeter_acceleration = 0 ; post_process = ; pressure_advance = 0 ; resolution = 0 ; retract_before_travel = 4 ; retract_layer_change = 0 ; retract_length = 4 ; retract_length_toolchange = 10 ; retract_lift = 0.5 ; retract_restart_extra = 0 ; retract_restart_extra_toolchange = 0 ; retract_speed = 70 ; skirt_distance = 6 ; skirt_height = 1 ; skirts = 2 ; slowdown_below_layer_time = 5 ; spiral_vase = 1 ; standby_temperature_delta = -5 ; start_gcode = M84 S0\nG28 ; home all axes\n ; temperature = 210 ; threads = 4 ; toolchange_gcode = ; travel_speed = 80 ; use_firmware_retraction = 0 ; use_relative_e_distances = 0 ; use_volumetric_e = 0 ; vibration_limit = 0 ; wipe = 0 ; z_offset = 0 ; dont_support_bridges = 1 ; extrusion_width = 0 ; first_layer_height = 0.3 ; infill_only_where_needed = 0 ; interface_shells = 0 ; layer_height = 0.1 ; raft_layers = 0 ; seam_position = aligned ; support_material = 0 ; support_material_angle = 0 ; support_material_contact_distance = 0.2 ; support_material_enforce_layers = 0 ; support_material_extruder = 1 ; support_material_extrusion_width = 0 ; support_material_interface_extruder = 1 ; support_material_interface_layers = 3 ; support_material_interface_spacing = 0 ; support_material_interface_speed = 100% ; support_material_pattern = pillars ; support_material_spacing = 2.5 ; support_material_speed = 50 ; support_material_threshold = 0 ; xy_size_compensation = 0 ; bottom_solid_layers = 1 ; bridge_flow_ratio = 1 ; bridge_speed = 60 ; external_fill_pattern = rectilinear ; external_perimeter_extrusion_width = 0 ; external_perimeter_speed = 80% ; external_perimeters_first = 0 ; extra_perimeters = 1 ; fill_angle = 45 ; fill_density = 0% ; fill_pattern = rectilinear ; gap_fill_speed = 20 ; infill_every_layers = 2 ; infill_extruder = 1 ; infill_extrusion_width = 0 ; infill_overlap = 15% ; infill_speed = 50 ; overhangs = 1 ; perimeter_extruder = 1 ; perimeter_extrusion_width = 0 ; perimeter_speed = 50 ; perimeters = 1 ; small_perimeter_speed = 90% ; solid_infill_below_area = 70 ; solid_infill_every_layers = 0 ; solid_infill_extruder = 1 ; solid_infill_extrusion_width = 0 ; solid_infill_speed = 80% ; thin_walls = 1 ; top_infill_extrusion_width = 0 ; top_solid_infill_speed = 80% ; top_solid_layers = 0
Re: Strange rings pattern on my delta May 26, 2015 01:54PM |
Re: Strange rings pattern on my delta May 26, 2015 02:16PM |
Re: Strange rings pattern on my delta May 26, 2015 04:03PM |
roboprint
What pulleys, belts, motors are you using? I'm using 16-teeth pulleys (GT2 belts) with 200-steps/rev motors and 1/16 microstepping, so it is 100 steps/mm for each carriage.
Re: Strange rings pattern on my delta July 31, 2015 10:41AM |
