I'm building a Delta. May 16, 2015 12:49AM |
Re: I'm building a Delta. October 07, 2015 11:26PM |
Re: I'm building a Delta. October 08, 2015 03:35AM |
Re: I'm building a Delta. October 08, 2015 07:02AM |
Bigger problem will be quick wearing out of the universal joints. This will lead to play in them which will dwarf any tilt in the linear bearings. Looks like frame will be stiff enough. That would mean that the next problem will be rather low young modulus of glass core GT2 belts. It the belts use glass core as it is common. Anyway this will get significant only at higher accelerations.Quote
o_lampe
There's only one linear bearing per rod?
I hope you don't use the cheap ones, because any tilt in the carriers have a huge influence.
Re: I'm building a Delta. October 08, 2015 10:28AM |
