My electronic setup is not working. Any advice is apreciated.
Here is my configuration.h file for Marlin 3dr v2 firmware. [
jmp.sh]
I am also sharing photograph of ramps 1.4. [
jmp.sh] [
jmp.sh]. In the image I have attached x,y,z motors, hot-end and hot-end thermistor, x,y,z endstops. Whenever i give command on pronterface for x,y or z motor to move all the motors move at the same time. Its like chaos. It doesn't matter which button i click any motor will move.
However hotend is working fine.
I changed in this line "const bool X_ENDSTOPS_INVERTING = false" from 'true' to 'false'. Also I am using mechanical endstops. [
jmp.sh]. I have a little doubt regarding which pin to connect on ramps. What changes to do on the above code.
I checked board using other marlin version Marlin 1.02 for Prusa i3. It was working as it should properly. Please help
