Marlin 1.0.2 for delta? July 04, 2015 11:44AM |
Re: Marlin 1.0.2 for delta? July 04, 2015 02:58PM |
Re: Marlin 1.0.2 for delta? July 05, 2015 05:29AM |
Re: Marlin 1.0.2 for delta? September 13, 2015 09:45PM |
Re: Marlin 1.0.2 for delta? September 13, 2015 10:54PM |
Re: Marlin 1.0.2 for delta? September 14, 2015 09:41AM |
3DRapidClone
download the firmware, and also download the Arduino IDE.
Hook up the Arduino board and open the .ino file in the folder. Go to configuration.h and this is where you change your settings. Make sure you are set to Atmega 2560 and the right com port, then flash your firmware on. I recommend Repetier instead of Marlin though for Deltas. (same process) good luck.
Re: Marlin 1.0.2 for delta? September 14, 2015 09:52AM |
Smallj
3DRapidClone
where can i download the firmware?
Smallj
I have configured my printer with marlin 1.0.0 right now but i have a problem with the servo motor twitching, this is why i want to get the v1.0.2. Does repietier firmware support auto bed leveling?
Re: Marlin 1.0.2 for delta? September 14, 2015 11:04AM |
Smallj
3DRapidClone
Re: Marlin 1.0.2 for delta? September 14, 2015 02:12PM |
Re: Marlin 1.0.2 for delta? September 14, 2015 03:13PM |
Smallj
What is the difference between auto level and auto calibration? How would I get around the limited 5 volt power? Could the limited power cause the servo to twitch. It only twitches when the motor are energized, so I am guessing yes, but I still want to ask
Re: Marlin 1.0.2 for delta? September 14, 2015 07:33PM |
Koenig
Smallj
The twitching servo is not an uncommon problem when also trying to use a LCD, hence the specific question from me.
I think the best was is to add an external 5V supply for the LCD.
I've heard of people modding the existing 5V regulator on the RAMPS to give more power, a quick google gives this, they even mention the LCD there.
Re: Marlin 1.0.2 for delta? September 14, 2015 07:40PM |
3DRapidClone
Smallj
3DRapidClone
Repetier supports Auto-leveling, it does not support auto-calibration. There are branches of Marlin that have auto-calibration however.
Re: Marlin 1.0.2 for delta? September 15, 2015 03:36AM |
Smallj
Koenig
Smallj
Okay i have done some searching, but i dont really know what im looking for. How would i add an external 5 volt power supply? I thought about modding the arduino but i dont really want to do that, i would rather add a power supply. I know there is a 5 volt power input on the arduino itself, would i need something like This or would i need to run something in line with the lcd display itself. I am sorry i seem helpless, i am stuck and dont know what i am looking for
Re: Marlin 1.0.2 for delta? September 15, 2015 03:38AM |
Smallj
3DRapidClone
Smallj
3DRapidClone
what is the difference between auto leveling and auto calibration?
Re: Marlin 1.0.2 for delta? September 15, 2015 09:39AM |
Re: Marlin 1.0.2 for delta? September 15, 2015 04:31PM |
Re: Marlin 1.0.2 for delta? September 15, 2015 07:43PM |
