DELTA leveling issue. August 13, 2015 06:57AM |
Re: DELTA leveling issue. August 13, 2015 11:52AM |
Re: DELTA leveling issue. August 13, 2015 12:09PM |
Re: DELTA leveling issue. August 13, 2015 12:19PM |
Re: DELTA leveling issue. August 13, 2015 12:21PM |
Re: DELTA leveling issue. August 13, 2015 12:23PM |
Re: DELTA leveling issue. August 13, 2015 12:30PM |
Re: DELTA leveling issue. August 13, 2015 12:32PM |
Re: DELTA leveling issue. August 13, 2015 12:33PM |
Re: DELTA leveling issue. August 13, 2015 12:35PM |
Re: DELTA leveling issue. August 13, 2015 12:36PM |
Re: DELTA leveling issue. August 13, 2015 01:03PM |
Re: DELTA leveling issue. August 13, 2015 01:33PM |
Re: DELTA leveling issue. August 13, 2015 03:18PM |
Re: DELTA leveling issue. August 13, 2015 03:55PM |
Re: DELTA leveling issue. August 13, 2015 04:40PM |
Re: DELTA leveling issue. August 13, 2015 04:46PM |
dipenjungi
when i did paper test these value i got now i don't know how to correct this,
X tower paper test value
X:88.33Y:-51.00Z:0.00E:0.00 Count X: 245.00Y:169.75Z:169.75
Y tower paper test value
X:-88.33Y:-51.00Z:-2.30E:0.00 Count X: 167.44Y:242.68Z:167.43
Z tower paper test value
X:0.00Y:100.00Z:-0.40E:0.00 Count X: 171.13Y:171.13Z:244.59
ORIGIN paper test valu
X:0.00Y:0.00Z:-10.30E:0.00 Count X: 212.49Y:212.49Z:212.49
Re: DELTA leveling issue. August 13, 2015 04:51PM |
Re: DELTA leveling issue. August 13, 2015 05:55PM |
>>> M501 SENDING:M501 echotored settings retrieved echo
teps per unit: echo: M92 X100.00 Y100.00 Z100.00 E443.09 echo:Maximum feedrates (mm/s): echo: M203 X200.00 Y200.00 Z200.00 E200.00 echo:Maximum Acceleration (mm/s2): echo: M201 X1000 Y1000 Z1000 E9000 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S500.00 T4000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E20.00 echo:Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echo:Endstop adjustment (mm): echo: M666 X-5.65 Y-6.70 Z-6.60 echo
elta Geometry adjustment: echo: M666 A0.00 B0.00 C0.00 E0.00 F0.00 G0.00 R89.50 D222.87 H177.20 P0.00 echo
ID settings: echo: M301 P21.28 I2.37 D47.76
Re: DELTA leveling issue. August 14, 2015 04:44AM |
Re: DELTA leveling issue. August 14, 2015 08:19AM |
