Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 09:48AM |
M665 R105.08 L214.350 B90 H236.31 X-0.20 Y-0.98 M666 X-1.26 Y0.56 Z0.70 ; put your endstop adjustments here, or let auto calibration find them M92 X100 Y100 Z100 ; Set axis steps/mm M906 X1000 Y1000 Z1000 E700 ; Set motor currents (mA) M201 X5000 Y5000 Z5000 E5000 ; Accelerations (mm/s^2) M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min) M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 09:55AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 11:37AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 12:00PM |
G1 Z3.295 X21.872 Y11.691 E151.38588 G1 Z3.297 X21.272 Y12.750 E151.43683 G1 Z3.300 X20.452 Y14.018 E151.50004 G1 Z3.3 F4800.000 G1 X20.452 Y14.018 F4800.000 G1 Z3.302 X19.920 Y14.773 E151.53873 F2400.000 G1 Z3.304 X19.171 Y15.733 E151.58968 G1 Z3.306 X18.376 Y16.655 E151.64063
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 01:16PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 01:30PM |
dc42
This pattern is repeated every 0.3mm, always at X20.452 Y14.018. Does this XY position correspond to the position of the seam in your print? There are 2 null moves, which the firmware should be throwing away, but perhaps something else is happening.
dc42
One useful thing you could do is connect with Pronterface and send M111 S1 P4 to enable Move module debugging. Then start the print from the SD card however you normally do it, and see if any diagnostics are reported to Pronterface.
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 02:27PM |
dc42
Connecting... Printer is now online. >>> M111 S1 P4 SENDING:M111 S1 P4 Debugging enabled for modules: Move Class Move spinning. >>> G28 SENDING:G28 File Calibration/cylinder-25-200-1024_03_noauto.gcode selected for printing Class Move spinning. Printing paused Class Move spinning.
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 03:01PM |
G1 Z4.306 X-0.000 Y24.800 E173.36486 G1 Z4.308 X-1.217 Y24.770 E173.41582 G1 Z4.310 X-2.431 Y24.681 E173.46677 G1 Z4.313 X-3.639 Y24.532 E173.51772 G1 Z4.315 X-4.838 Y24.323 E173.56868 G1 Z4.317 X-6.026 Y24.057 E173.61963 G1 Z4.320 X-7.199 Y23.732 E173.67059 G1 Z4.322 X-8.355 Y23.350 E173.72154 G1 Z4.325 X-9.491 Y22.912 E173.77249 G1 Z4.327 X-10.603 Y22.419 E173.82345 G1 Z4.329 X-11.691 Y21.872 E173.87440 G1 Z4.332 X-12.750 Y21.272 E173.92536 G1 Z4.334 X-13.778 Y20.620 E173.97631 G1 Z4.336 X-14.773 Y19.920 E174.02727 G1 Z4.339 X-15.733 Y19.171 E174.07822 G1 Z4.341 X-16.655 Y18.376 E174.12917 G1 Z4.343 X-17.536 Y17.536 E174.18013 G1 Z4.346 X-18.376 Y16.655 E174.23108 G1 Z4.348 X-19.171 Y15.733 E174.28204 G1 Z4.350 X-19.920 Y14.773 E174.33299 G1 Z4.353 X-20.620 Y13.778 E174.38394 G1 Z4.355 X-21.272 Y12.750 E174.43490 G1 Z4.357 X-21.872 Y11.691 E174.48585 G1 Z4.360 X-22.419 Y10.603 E174.53681 G1 Z4.362 X-22.912 Y9.491 E174.58776 G1 Z4.364 X-23.350 Y8.355 E174.63871 G1 Z4.367 X-23.732 Y7.199 E174.68967 G1 Z4.369 X-24.057 Y6.026 E174.74062 G1 Z4.371 X-24.323 Y4.838 E174.79158 G1 Z4.374 X-24.532 Y3.639 E174.84253 G1 Z4.376 X-24.681 Y2.431 E174.89349 G1 Z4.378 X-24.770 Y1.217 E174.94444 G1 Z4.381 X-24.800 Y0.000 E174.99539
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 03:02PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 03:10PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 03:32PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 03:42PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 03:44PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 03:53PM |
Koenig
I can definitely reproduce the behaviour:
That bump is right in between the X and Z-tower.
Higher res for those who want: [someimage.com]
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 04:36PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 18, 2015 05:36PM |
dc42
I've just run the print again, and I can hear when the seams occur. It's at the inflexion points of the carriages. I suspect it is caused by numerical error causing the transition between different phases of motion to be not entirely smooth - which is also the main suspect for the other issue. I hope to have more news tomorrow.
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 19, 2015 02:58AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 19, 2015 03:50AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 20, 2015 12:09PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 21, 2015 01:05PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 21, 2015 05:22PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 21, 2015 05:47PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 03:33AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 04:57AM |
latform Diagnostics: Memory usage: Program static ram used: 41428 Dynamic ram used: 43436 Recycled dynamic ram: 1152 Current stack ram used: 2872 Maximum stack ram used: 4244 Never used ram: 8044 Last reset 00:00:33 ago, cause: software Last software reset code & available RAM: 0x1004, 6948 Spinning module during software reset: Move Last message before reset: File Roses/Rose-cura.gcode selected for printing Error status: 0 Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Free file entries: 10 Longest block write time: 0.0ms Slowest main loop (seconds): 0.005907; fastest: 0.000048 Move Diagnostics: MaxReps: 0, StepErrors: 0 Heat Diagnostics: Heater 1: I-accumulator = 2.0 GCodes Diagnostics: Move available? no Network Diagnostics: Free connections: 15 of 16 Free transactions: 23 of 24 Free send buffers: 19 of 20 Webserver Diagnostics:
Platform Diagnostics: Memory usage: Program static ram used: 41428 Dynamic ram used: 43436 Recycled dynamic ram: 1152 Current stack ram used: 2872 Maximum stack ram used: 4276 Never used ram: 8012 Last reset 00:00:34 ago, cause: software Last software reset code & available RAM: 0x1004, 6948 Spinning module during software reset: Move Last message before reset: File Roses/Rose-cura.gcode selected for printing Error status: 0 Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Free file entries: 10 Longest block write time: 0.0ms Slowest main loop (seconds): 0.010330; fastest: 0.000046 Move Diagnostics: MaxReps: 0, StepErrors: 0 Heat Diagnostics: Heater 1: I-accumulator = 2.0 GCodes Diagnostics: Move available? no Network Diagnostics: Free connections: 14 of 16 Free transactions: 23 of 24 Free send buffers: 19 of 20 Webserver Diagnostics:
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 05:15AM |
Platform Diagnostics: Memory usage: Program static ram used: 41492 Dynamic ram used: 43436 Recycled dynamic ram: 1088 Current stack ram used: 2872 Maximum stack ram used: 4252 Never used ram: 8036 Last reset 00:00:33 ago, cause: software Last software reset code & available RAM: 0x1004, 6904 Spinning module during software reset: Move Last message before reset: File Roses/rose-test-hang-cura.gcode selected for printing Error status: 0 Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Free file entries: 10 Longest block write time: 0.0ms Slowest main loop (seconds): 0.010323; fastest: 0.000048 Move Diagnostics: MaxReps: 0, StepErrors: 0 Heat Diagnostics: Heater 1: I-accumulator = 2.0 GCodes Diagnostics: Move available? no Network Diagnostics: Free connections: 15 of 16 Free transactions: 23 of 24 Free send buffers: 19 of 20 Webserver Diagnostics:
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 06:08AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 06:21AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 06:22AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 06:44AM |
Connecting... Printer is now online. Debugging enabled for modules: Move(4) Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Heat(5) DDA(6) PrintMonitor(7) File Roses/rose-test-hang-cura.gcode selected for printing
13:32:03 Connection established! 13:31:55 Disconnected. 13:29:48 M32 Roses/rose-test-hang-cura.gcode File Roses/rose-test-hang-cura.gcode selected for printing 13:29:04 M111 S1 P4 Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Heat(5) DDA(6) PrintMonitor(7) 13:28:54 Connection established! 13:28:53 Page Load complete!
Platform Diagnostics: Memory usage: Program static ram used: 41492 Dynamic ram used: 43436 Recycled dynamic ram: 1088 Current stack ram used: 2872 Maximum stack ram used: 4196 Never used ram: 8092 Last reset 00:00:22 ago, cause: software Last software reset code & available RAM: 0x1004, 7036 Spinning module during software reset: Move Last message before reset: File Roses/rose-test-hang-cura.gcode selected for printing Error status: 0 Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Free file entries: 10 Longest block write time: 0.0ms Slowest main loop (seconds): 0.006498; fastest: 0.000048 Move Diagnostics: MaxReps: 0, StepErrors: 0 Heat Diagnostics: Heater 1: I-accumulator = 2.0 GCodes Diagnostics: Move available? no Network Diagnostics: Free connections: 15 of 16 Free transactions: 23 of 24 Free send buffers: 19 of 20 Webserver Diagnostics:
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 07:01AM |
