Bad print quality with Rostock Delta August 25, 2015 01:35PM |
Re: Bad print quality with Rostock Delta August 25, 2015 02:44PM |
TehStranger
Hello,
As some of you may know I recently built an Original Rostock Delta machine and I finally got the levelling sorted out but the quality of the prints is quite bad.
I think It's because of the printed arms I am using which is creating a lot of vibration/backlash.
My hotend is an E3D clone, I'm also thinking it could be the source of the problem, well one of them anyway.
I've attached images to this post.
That was printed at 0.2 layer height at 50mm/s.
Thanks.
Re: Bad print quality with Rostock Delta August 25, 2015 03:09PM |
MrMeeeseeeks
TehStranger
Hello,
Thanks.
When you say vibration/backlash do you mean the motors sound like they're skipping?
Re: Bad print quality with Rostock Delta August 25, 2015 03:31PM |
Re: Bad print quality with Rostock Delta August 25, 2015 10:51PM |
etfrench
Which slicer program are you using?
What material?
What temperature is the hot end?
Heated bed? If so, what temperature?
What speed?
What are your retraction settings?
Have you calibrated the extruder?
Have you tried slowing the speeds down until the arms are stable?
I'd recommend printing some of the calibration objects available on thingiverse so you can get a better idea of what's causing the failure.
Re: Bad print quality with Rostock Delta August 26, 2015 01:48AM |
Re: Bad print quality with Rostock Delta August 26, 2015 10:15AM |
