Kossel 2020 autolevel z-probe not homing, not stopping
Posted by djtrance2
September 07, 2015 03:31AM
Hi all,
I've loaded the Kossel Mini firmware onto this printer. This is a Ramps 1.4.
I have z = 0mm being the bottom position, close to the bed, and 315mm it on the top, when the 3 carriages hit the stops.
I have not been able to run a home to 0 position and have the probe go toward the bed. Additionally, when the probe is moving in the z-direction, I'm holding a metal wrench close to the inductive probe, but nothing stops.
The inductive probe red LED is always lit, partially. When I bring the metal wrench around it, I see the light be brighter, but it doesn't go from no light to light, just some light to more light.
How do we configure the 0 position? I watched a lot of videos about setting the head to be 0.2mm from the bed, but I can't seem to set the 0 position.
Re: Kossel 2020 autolevel z-probe not homing, not stopping
September 07, 2015 03:37AM
What does "m119" tell you about the state of the z-probe when it´s partially lit and fully lit?
Is the sensor too close to the hotend?
Do you have to invert the signal?
-Olaf
Edited 1 time(s). Last edit at 09/07/2015 03:39AM by o_lampe.
September 13, 2015 06:30PM
What sensor are you using? And how is it wire up?
The normally 12mm sensor is 12volts and needes resistors to work.
Also it will need a ground and output 5volts qhen trigged.
But do the comman listed above.
It will check for the end stop status.
While the probe is in the air not touching the bed. It should read " open".
When metal is by it, it should light up and read "triggered".
Do this command read the status.
Then place a metal by the sensor and do cammon again
Edited 1 time(s). Last edit at 09/13/2015 06:32PM by xile6.
