print issue - incosistent travel speeds while printing September 23, 2015 01:16AM |
Re: print issue - incosistent travel speeds while printing September 23, 2015 04:19AM |
Re: print issue - incosistent travel speeds while printing September 23, 2015 09:51PM |
Re: print issue - incosistent travel speeds while printing September 23, 2015 10:06PM |
Re: print issue - incosistent travel speeds while printing September 23, 2015 11:20PM |
Re: print issue - incosistent travel speeds while printing September 23, 2015 11:52PM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 01:38AM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 04:37AM |
#include U8glib.h ... #define MOTHERBOARD 33
Re: print issue - incosistent travel speeds while printing September 24, 2015 07:57AM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 09:25AM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 10:45AM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 05:52PM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 06:53PM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 07:26PM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 07:50PM |
Re: print issue - incosistent travel speeds while printing September 24, 2015 08:43PM |
pulse69
One more thing. If I buy a Duet board, can i still use the Reprap graphic display?
Re: print issue - incosistent travel speeds while printing September 25, 2015 02:02AM |
Re: print issue - incosistent travel speeds while printing September 25, 2015 03:32AM |
Re: print issue - incosistent travel speeds while printing September 25, 2015 04:39AM |
Re: print issue - incosistent travel speeds while printing September 25, 2015 09:59AM |
Re: print issue - incosistent travel speeds while printing September 27, 2015 09:24PM |
o_lampe
Since it´s a delta, we should consider bad calibration.
There´s no word about flatness of the head-moves, tower and center calibrated.
Have you done all the calibration steps, before you tried to print?
Did you use auto bed level?
-Olaf
Re: print issue - incosistent travel speeds while printing September 27, 2015 09:28PM |
Re: print issue - incosistent travel speeds while printing September 28, 2015 03:02AM |
Re: print issue - incosistent travel speeds while printing September 29, 2015 04:48AM |
pulse69
Hi Guys, I reduced the number of segments/second to 100 and the problems seem to have gone away. I'll try turning the screen back on now.
#define LCD_UPDATE_INTERVAL 200 //was 100
Re: print issue - incosistent travel speeds while printing October 05, 2015 07:36AM |
Re: print issue - incosistent travel speeds while printing October 05, 2015 07:27PM |
Khalid
hercek
It looks like like line buffer under-run, i.e. small cpu resources for the requested task.
Try to lower DELTA_SEGMENTS_PER_SECOND to 100 or may be even to 80.
It should help if I'm right.
also lower the refresh rate of SMART GRAPHIC DISPLAY
Re: print issue - incosistent travel speeds while printing October 06, 2015 09:17AM |
it is more like lowering delta segments per second decreases printer precision. But really 100 is good enough.Quote
o_lampe
pulse69
Good to know it´s a firmware problem.
Sad thing, with this setting you slow down a printer that is meant to print faster than Cartesians or other designs.
