FSR Autocalibration Issue September 25, 2015 06:49PM |
Re: FSR Autocalibration Issue September 26, 2015 04:10AM |
Re: FSR Autocalibration Issue September 26, 2015 03:30PM |
Re: FSR Autocalibration Issue September 26, 2015 08:22PM |
Re: FSR Autocalibration Issue September 27, 2015 08:21AM |
Re: FSR Autocalibration Issue September 27, 2015 10:28PM |
o_lampe
It seems, you can solve the problem by raising the y-tower endstop or shorten ( screw in) the endstop adjuster screw by 1-2mm.
Do you run "M502 & M500" commands every time you start a print? You could as well switch off the EEprom, because it doesn´t have any added value this way...
I´d run M502 only when I´ve flashed a new firmware.
-Olaf
PS: How come, we don´t find any documentation about the magic G30 A command in RR-wiki or on marlin G-code Wiki?
Re: FSR Autocalibration Issue September 28, 2015 08:59PM |
Re: FSR Autocalibration Issue September 29, 2015 04:31AM |
kgrocker13
When the print head tapped the bed, it was triggering the FSRs multiple times in rapid succession
#define Z_MIN_PROBE_REPEATABILITY_TEST?
