Delta cal torture October 07, 2015 09:10PM |
Re: Delta cal torture October 08, 2015 01:11AM |
Re: Delta cal torture October 08, 2015 03:21AM |
Re: Delta cal torture October 08, 2015 01:53PM |
Re: Delta cal torture October 08, 2015 05:12PM |
Re: Delta cal torture October 08, 2015 09:43PM |
Re: Delta cal torture October 09, 2015 12:31AM |
Tennysballs
I have my steppers set 16th steps. Which I kind of arbitrarily chose. Poor choice?
I'm having a hard time finding instruction on how to tune the A4988s. Just a lot of discussion. How do I go about that?
Re: Delta cal torture October 09, 2015 03:55AM |
Re: Delta cal torture October 09, 2015 10:07AM |
Re: Delta cal torture October 09, 2015 11:11AM |
Re: Delta cal torture October 09, 2015 03:14PM |
Re: Delta cal torture October 09, 2015 04:05PM |
Tennysballs
Olampe, Yeah that does sound pretty similar to what I am experiencing. Could be an under current issue. When you say decay hack, is that the same thing as the r4 hack? Should I try and tune the pots before I do that? Because from what I have been reading, I can't really find a solid value for what vref should be.
Re: Delta cal torture October 10, 2015 04:04AM |
Re: Delta cal torture October 10, 2015 04:32AM |
o_lampe
I don't trust the wiki-formulas regarding the DRV8825 too much. I had a DRV8825 running stable at 2.4V on a 1.7A stepper. Regarding the formula, this would have been 4.8A ?!
IIRC the formula was Vref = Imax *2....
But the A4988 formulas look right to me as long, as you identify the Rs value of your drivers.
-Olaf
Re: Delta cal torture October 10, 2015 09:41AM |
Re: Delta cal torture October 10, 2015 02:32PM |
Re: Delta cal torture October 10, 2015 02:46PM |
Tennysballs
My data sheet doesn't say anything about Max current. Just current per phase. 1.5A. Does that sound right at all?
Tennysballs
And I'm not sure about the backlash. Maybe I don't understand backlash, but I thought it was only really applicable to gears
Re: Delta cal torture October 10, 2015 02:52PM |
Re: Delta cal torture October 11, 2015 06:13PM |
Re: Delta cal torture October 12, 2015 03:38AM |
Tennysballs
So this kind of sucks. But in a way it's good because it's something. So I tuned my motors to ~480mv Vref using the following data.
Current/phase of motors = 1.5A
70% of 1.5A = 1.2A
Vref = I_TripMax * 8 * Rs
= 1.2A * 8 * .05ohms
=480mv
Did I tune them right?
Re: Delta cal torture October 12, 2015 03:48AM |
Re: Delta cal torture October 12, 2015 03:57AM |
dc42
Tennysballs
70% of 1.5A = 1.2A
=480mv
You have assumed that your drivers use 0.05 ohm sense resistors. A few do (AFAIR the Pololu Black Edition and T3P3 Ice Blue), but most others use 0.1 ohm resistors. So you may be running your motors at only 40% of their rated current. If you really are running them at 1.2A then the motors will be getting warm and the drivers will be getting very hot. If everything is running cool then try 800mV instead.
In your calculation, I presume you meant 80%, not 70%.
Re: Delta cal torture October 12, 2015 02:21PM |
Re: Delta cal torture October 12, 2015 03:02PM |
Tennysballs
Since the problem was persisting, I jumped into the firmware(Marlin) to look around. I'm using 16th steps. Since I am using Rich's spool design from his 3DR(and his default steps per unit), I double checked to see if maybe he was using a different step rate and if changing it would make a difference. I couldn't really find any solid information on it, but it seemed that he might have been using 8th steps. I doubled his 55.5 steps/unit just to see what happened and my problem of inconsistent response went away-it would move every time I would press the .1mm button. The problem was that when I got to what should be Z0 in M114, I was at about half of my total Z height. So I guess I had the right step rates. I'm not sure what to make of all that....
Re: Delta cal torture October 12, 2015 04:28PM |
Re: Delta cal torture October 12, 2015 04:39PM |
Re: Delta cal torture October 12, 2015 04:41PM |
Re: Delta cal torture October 12, 2015 04:57PM |
Tennysballs
18mm diameter spools with spectra line. 16th steps.
Re: Delta cal torture October 12, 2015 07:30PM |
Re: Delta cal torture October 13, 2015 03:20AM |
