[Kossel Mini] ABL not working on Marlin1.1.0RC2 "Probe (F)ront position out of rang"
October 27, 2015 11:56AM
Edit: Got another Problem now. See this Thread
hi guys,
i guess this is just a configuration issue, but i have no idea whats wrong.
I wanted to update to Marlin 1.1.0RC2 and diffed the configuration.h and configuration_adv,h.
Now when i try to autolevel my bed with G29 i get the error:
>>> G29
SENDING:G29
G29 Auto Bed Leveling
?Probe (F)ront position out of range.
I don't know if the probing area is set up correct. Just used the values that worked for my old Marlin version.
Edit:
Also, with some other settings i don't remember right now, after probe deploy the head drove out of the printing area (to the right).
My config (shortened):
configuration.h:
#define DELTA
#if ENABLED(DELTA)
// Make delta curves from many straight lines (linear interpolation).
// This is a trade-off between visible corners (not enough segments)
// and processor overload (too many expensive sqrt calls).
#define DELTA_SEGMENTS_PER_SECOND 200
// NOTE NB all values for DELTA_* values MUST be floating point, so always have a decimal point in them
// Center-to-center distance of the holes in the diagonal push rods.
#define DELTA_DIAGONAL_ROD 214.0 // mm
// Horizontal offset from middle of printer to smooth rod center.
#define DELTA_SMOOTH_ROD_OFFSET 145.0 // mm
// Horizontal offset of the universal joints on the end effector.
#define DELTA_EFFECTOR_OFFSET 19.9 // mm
// Horizontal offset of the universal joints on the carriages.
#define DELTA_CARRIAGE_OFFSET 19.5 // mm
// Horizontal distance bridged by diagonal push rods when effector is centered.
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET)
// Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers).
#define DELTA_PRINTABLE_RADIUS 95
#endif
const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_PROBE_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS // Deltas only use min endstops for probing.
//============================ Bed Auto Leveling ============================
// @section bedlevel
#define AUTO_BED_LEVELING_FEATURE // Delete the comment to enable (remove // at the start of the line)
//#define DEBUG_LEVELING_FEATURE
//#define Z_MIN_PROBE_REPEATABILITY_TEST  // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled.
#if ENABLED(AUTO_BED_LEVELING_FEATURE)
// There are 2 different ways to specify probing locations:
// - "grid" mode
//   Probe several points in a rectangular grid.
//   You specify the rectangle and the density of sample points.
//   This mode is preferred because there are more measurements.
// - "3-point" mode
//   Probe 3 arbitrary points on the bed (that aren't colinear)
//   You specify the XY coordinates of all 3 points.
// Enable this to sample the bed in a grid (least squares solution).
// Note: this feature generates 10KB extra code size.
#define AUTO_BED_LEVELING_GRID  // Deltas only support grid mode.
#if ENABLED(AUTO_BED_LEVELING_GRID)
// set the rectangle in which to probe
  #define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS - 10)
  #define LEFT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
  #define RIGHT_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
  #define FRONT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
  #define BACK_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
//#define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS-20)   //MR: Changed from (DELTA_PRINTABLE_RADIUS-10)
//#define LEFT_PROBE_BED_POSITION (10-DELTA_PROBABLE_RADIUS)  //MR: Changed from -DELTA_PROBABLE_RADIUS
//#define RIGHT_PROBE_BED_POSITION (DELTA_PROBABLE_RADIUS-10) //MR: Changed from DELTA_PROBABLE_RADIUS
//#define BACK_PROBE_BED_POSITION (DELTA_PROBABLE_RADIUS-10)  //MR: Changed from DELTA_PROBABLE_RADIUS
//#define FRONT_PROBE_BED_POSITION (10-DELTA_PROBABLE_RADIUS) //MR: Changed from -DELTA_PROBABLE_RADIUS
#define MIN_PROBE_EDGE 10 // The Z probe square sides can be no smaller than this.
// Non-linear bed leveling will be used.
// Compensate by interpolating between the nearest four Z probe values for each point.
// Useful for deltas where the print surface may appear like a bowl or dome shape.
// Works best with ACCURATE_BED_LEVELING_POINTS 5 or higher.
#define AUTO_BED_LEVELING_GRID_POINTS 2
#else  // !AUTO_BED_LEVELING_GRID
// Arbitrary points to probe.
// A simple cross-product is used to estimate the plane of the bed.
      #define ABL_PROBE_PT_1_X 15
      #define ABL_PROBE_PT_1_Y 180
      #define ABL_PROBE_PT_2_X 15
      #define ABL_PROBE_PT_2_Y 20
      #define ABL_PROBE_PT_3_X 170
      #define ABL_PROBE_PT_3_Y 20
      #define ABL_PROBE_PT_1_X 0
      #define ABL_PROBE_PT_1_Y 70
      #define ABL_PROBE_PT_2_X -60
      #define ABL_PROBE_PT_2_Y -35
      #define ABL_PROBE_PT_3_X 60
      #define ABL_PROBE_PT_3_Y -35
#endif // AUTO_BED_LEVELING_GRID
// Offsets to the Z probe relative to the nozzle tip.
// X and Y offsets must be integers.
#define X_PROBE_OFFSET_FROM_EXTRUDER 0.0   //MR: Changed from 3.5
#define Y_PROBE_OFFSET_FROM_EXTRUDER 16    //MR: Changed from 17
#define Z_PROBE_OFFSET_FROM_EXTRUDER -3.45  // Z probe to nozzle Z offset: -below (always!)
#define Z_RAISE_BEFORE_HOMING 4      // (in mm) Raise Z axis before homing (G28) for Z probe clearance.
// Be sure you have this distance over your Z_MAX_POS in case.
#define XY_TRAVEL_SPEED 1000         // X and Y axis travel speed between probes, in mm/min.
#define Z_RAISE_BEFORE_PROBING 15   // How much the Z axis will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 2  // How much the Z axis will be raised when traveling from between next probing points
#define Z_RAISE_AFTER_PROBING 50    // How much the Z axis will be raised after the last probing point.
//#define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10" // These commands will be executed in the end of G29 routine.
// Useful to retract a deployable Z probe.
//#define Z_PROBE_SLED // Turn on if you have a Z probe mounted on a sled like those designed by Charles Bell.
//#define SLED_DOCKING_OFFSET 5 // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// Allen key retractable z-probe as seen on many Kossel delta printers - [reprap.org]
// Deploys by touching z-axis belt. Retracts by pushing the probe down. Uses Z_MIN_PIN.
#define Z_PROBE_ALLEN_KEY
#if ENABLED(Z_PROBE_ALLEN_KEY)
// 2 or 3 sets of coordinates for deploying and retracting the spring loaded touch probe on G29,
// if servo actuated touch probe is not defined. Uncomment as appropriate for your printer/probe.
// Kossel Mini
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_X 30.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_Y DELTA_PRINTABLE_RADIUS
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_Z 100.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_FEEDRATE XY_TRAVEL_SPEED
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_X 5.0 // 0
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_Y DELTA_PRINTABLE_RADIUS
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_Z 100.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_FEEDRATE (XY_TRAVEL_SPEED/10)
#define Z_PROBE_ALLEN_KEY_STOW_DEPTH 15
// Move the probe into position
#define Z_PROBE_ALLEN_KEY_STOW_1_X -21 // -64
#define Z_PROBE_ALLEN_KEY_STOW_1_Y 93 // 56
#define Z_PROBE_ALLEN_KEY_STOW_1_Z 24 // 23
#define Z_PROBE_ALLEN_KEY_STOW_1_FEEDRATE XY_TRAVEL_SPEED
// Move the nozzle down further to push the probe into retracted position.
#define Z_PROBE_ALLEN_KEY_STOW_2_X  Z_PROBE_ALLEN_KEY_STOW_1_X
#define Z_PROBE_ALLEN_KEY_STOW_2_Y  Z_PROBE_ALLEN_KEY_STOW_1_Y
#define Z_PROBE_ALLEN_KEY_STOW_2_Z  (Z_PROBE_ALLEN_KEY_STOW_1_Z-Z_PROBE_ALLEN_KEY_STOW_DEPTH)
#define Z_PROBE_ALLEN_KEY_STOW_2_FEEDRATE (XY_TRAVEL_SPEED/10)
// Raise things back up slightly so we don't bump into anything
#define Z_PROBE_ALLEN_KEY_STOW_3_X  Z_PROBE_ALLEN_KEY_STOW_2_X
#define Z_PROBE_ALLEN_KEY_STOW_3_Y  Z_PROBE_ALLEN_KEY_STOW_2_Y
#define Z_PROBE_ALLEN_KEY_STOW_3_Z  (Z_PROBE_ALLEN_KEY_STOW_1_Z+Z_PROBE_ALLEN_KEY_STOW_DEPTH)
#define Z_PROBE_ALLEN_KEY_STOW_3_FEEDRATE (XY_TRAVEL_SPEED/2)
#endif
// If you have enabled the bed auto leveling and are using the same Z probe for Z homing,
// it is highly recommended you let this Z_SAFE_HOMING enabled!!!
#define Z_SAFE_HOMING   // This feature is meant to avoid Z homing with Z probe outside the bed area.
// When defined, it will:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers timeout, it will need X and Y homing again before Z homing.
// - Position the Z probe in a defined XY point before Z Homing when homing all axis (G28).
// - Block Z homing only when the Z probe is outside bed area.
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2)    // X point for Z homing when homing all axis (G28).
#define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2)    // Y point for Z homing when homing all axis (G28).
#endif
// Support for a dedicated Z probe endstop separate from the Z min endstop.
// If you would like to use both a Z probe and a Z min endstop together,
// uncomment #define Z_MIN_PROBE_ENDSTOP and read the instructions below.
// If you still want to use the Z min endstop for homing, disable Z_SAFE_HOMING above.
// Example: To park the head outside the bed area when homing with G28.
// WARNING:
// The Z min endstop will need to set properly as it would without a Z probe
// to prevent head crashes and premature stopping during a print.
// To use a separate Z probe endstop, you must have a Z_MIN_PROBE_PIN
// defined in the pins_XXXXX.h file for your control board.
// If you are using a servo based Z probe, you will need to enable NUM_SERVOS,
// Z_ENDSTOP_SERVO_NR and SERVO_ENDSTOP_ANGLES in the R/C SERVO support below.
// RAMPS 1.3/1.4 boards may be able to use the 5V, Ground and the D32 pin
// in the Aux 4 section of the RAMPS board. Use 5V for powered sensors,
// otherwise connect to ground and D32 for normally closed configuration
// and 5V and D32 for normally open configurations.
// Normally closed configuration is advised and assumed.
// The D32 pin in Aux 4 on RAMPS maps to the Arduino D32 pin.
// Z_MIN_PROBE_PIN is setting the pin to use on the Arduino.
// Since the D32 pin on the RAMPS maps to D32 on Arduino, this works.
// D32 is currently selected in the RAMPS 1.3/1.4 pin file.
// All other boards will need changes to the respective pins_XXXXX.h file.
// WARNING:
// Setting the wrong pin may have unexpected and potentially disastrous outcomes.
// Use with caution and do your homework.
#endif // AUTO_BED_LEVELING_FEATURE
If you could help me, that would be great smiling smiley
-Culain
Edited 1 time(s). Last edit at 10/27/2015 11:58AM by Culain.
open | download - Configuration.h (44.6 KB)
