Kossel XL from Robotdigg October 30, 2015 04:03AM |
Re: Kossel XL from Robotdigg October 30, 2015 06:34AM |
4u2fast
i'm new to 3d printing and try to build the above mentioned printer, can anyone help me with the offsets of the machine ?
The 2020 profiles are 750mm and 360mm
In addition i'm looking for the best lenght for the rods.
thanks
Thomas
Re: Kossel XL from Robotdigg October 30, 2015 07:27AM |
Re: Kossel XL from Robotdigg October 30, 2015 12:45PM |
4u2fast
great, thanks for the information !
are you using the aluminuim parts from robotdigg ?
Thanks
Thomas
Re: Kossel XL from Robotdigg October 30, 2015 01:01PM |
Re: Kossel XL from Robotdigg October 30, 2015 01:19PM |
Re: Kossel XL from Robotdigg November 04, 2015 01:48AM |
Hello Also I'm building a Kossel XLQuote
dougal1957
I am actually in the process of building one of these for a customer.
We are using a 300 mm diameter bed with an AC Silicon heater pad and have set the rods to 343 mm long (centre to centre of the rod ends which in our case are IGUS drylin KBRM-03 ends) 350 would be slightly better I think and mine will be just that (I have one in progress for myself as well)
Re: Kossel XL from Robotdigg November 04, 2015 02:25AM |
Re: Kossel XL from Robotdigg November 04, 2015 02:27AM |
Re: Kossel XL from Robotdigg November 04, 2015 03:42AM |
Re: Kossel XL from Robotdigg November 05, 2015 02:11AM |
Re: Kossel XL from Robotdigg November 05, 2015 02:47AM |
4u2fast
Good morning,
could someone give me the figures for the Printer Radius, im using the MGN12 and Aluminium carriges. (360mm 2020)
not sure if 200 mm is ok ?!?!
Thanks
Thomas
Re: Kossel XL from Robotdigg November 05, 2015 02:54AM |
Re: Kossel XL from Robotdigg November 05, 2015 04:43AM |
Re: Kossel XL from Robotdigg November 05, 2015 05:14AM |
Re: Kossel XL from Robotdigg November 05, 2015 11:28AM |
Koenig
o_lampe
No way the printer radius is 200mm.
Maybe you meant printbed diameter?!
My delta is bigger, and I'm struggling with 140mm print radius.
-Olaf
If they use repetier the "Printer Radius" describes a different measurement than what is used in Marlin or RRF.
Re: Kossel XL from Robotdigg November 19, 2015 03:28AM |
Re: Kossel XL from Robotdigg April 18, 2016 01:37AM |
