24V fans on Duet
October 30, 2015 03:46PM
Guys
Need a little advice I am just coming to the wiring phase of a new Delta Build for a customer.
I am using 24V for this build and would like to know if there are any posts on the Expansion header where they may be 24 V to drive the Hotend and Duet Cooling fans?
Doug
Re: 24V fans on Duet
October 30, 2015 05:48PM
If you have the Duet 0.8.6 then there are two always-on fan headers. If you have the Duet 0.6 then you can pick up 24V from the motor loom connector. See the HOTEND FAN connection in [reprappro.com]. The same pins on the second row of that connector can be used for the other fan.
October 30, 2015 06:11PM
Thanks Dave new you would have the answer
By the way got the 5 inch panel Scad file about right now would you like me to send it back to you?
Doug
October 31, 2015 05:06AM
Yes please, either email it or post it here.
October 31, 2015 06:29AM
Dave
File attached
open | download - DougsModifiedPanelDueEnclosureWithLip.scad (16.3 KB)
October 31, 2015 07:33AM
Thanks, I've updated the repository with your changes.
