Stuttering Motors November 10, 2015 12:55AM |
Re: Stuttering Motors November 10, 2015 03:30AM |
Re: Stuttering Motors November 10, 2015 03:39AM |
Re: Stuttering Motors November 10, 2015 04:11AM |
Re: Stuttering Motors November 10, 2015 04:19AM |
nimrod
i printed with SD Card.
this is my second Kossel. the first, from t3p3 with arduino and Marlin works very smooth, and there aren't any Problems like this. the only differents between both printers are the Motors (the "old" have a higher Torque), the heated bed and the stepper driver ("old" 1/16 vs "new" 1/32)
also the firmware and the igus gliders are the same.
Re: Stuttering Motors November 10, 2015 04:41AM |
Koenig
nimrod
The 1/32 drivers take a huge chunk of the performance, double that of the 1/16.
When I had that combo, my printer maxed out at about 80mm/s in the XY-plane, but faster with pure Z travel moves.
I didn't have an LCD though.
Re: Stuttering Motors November 10, 2015 04:50AM |
Re: Stuttering Motors November 10, 2015 05:54AM |
Re: Stuttering Motors November 10, 2015 09:35AM |
nimrod
it sounds like it is better to replace the "better" drv8825 by the "old" 1/16er stepper.
Re: Stuttering Motors November 10, 2015 10:57AM |
Re: Stuttering Motors November 10, 2015 11:34AM |
hercek
Repetier has a chance to be quicker since it uses integer arithmetic for deltas which are not too big (i.e. a 16 bit integer overflow cannot happen).
Re: Stuttering Motors November 10, 2015 12:16PM |
Re: Stuttering Motors November 10, 2015 12:58PM |
Re: Stuttering Motors November 10, 2015 02:08PM |
Re: Stuttering Motors November 10, 2015 02:25PM |
Re: Stuttering Motors November 10, 2015 02:52PM |
Re: Stuttering Motors November 10, 2015 03:10PM |
Re: Stuttering Motors November 10, 2015 03:35PM |
nimrod
I have the Full graphics display Controller. My other kossel has a normal Lcd Display. Is it possible that this Is the Problem?
Re: Stuttering Motors November 10, 2015 03:44PM |
Re: Stuttering Motors November 10, 2015 06:15PM |
Re: Stuttering Motors November 11, 2015 01:41AM |
Re: Stuttering Motors November 11, 2015 02:38AM |
Re: Stuttering Motors November 11, 2015 09:57PM |
nimrod
I'm going to buy one, but for this project "Build a kossel without any Sets or kits" i prefered a simple Electronic. For the next Time, or the next Upgrade, a Duet Board Is in the top of my List.
Re: Stuttering Motors November 12, 2015 02:36AM |
Re: Stuttering Motors November 12, 2015 03:38AM |
grat
nimrod
Just remember, if you want on-board display for Duet, it's going to be Panel Due. Neither GLCD nor the 20x4 text LCD are supported.
