Which Alu-extrusion for robotdigg corners and T3P3 delrin rollers? November 25, 2015 03:42AM |
Re: Which Alu-extrusion for robotdigg corners and T3P3 delrin rollers? November 25, 2015 04:32AM |
o_lampe
Hi guys,
I wanted to upgrade my Delta with Robotdiggs Aluminum corners.
I used to use T-Nut 5 extrusions before and was happy with the delrin rollers from T3P3.
But now the extrusions don't fit in the Alu corners. Their extra inner guides are to wide for Nut 5. ( 5.6mm vs. 5mm )
Re: Which Alu-extrusion for robotdigg corners and T3P3 delrin rollers? November 25, 2015 05:24AM |
Re: Which Alu-extrusion for robotdigg corners and T3P3 delrin rollers? November 25, 2015 05:53AM |
o_lampe
Thanks David, that was my "plan B" too.
I don't want to order extrusions from robotdigg or US_openbeam stuff, since they are 800mm long and shipping would be pretty expensive.
The other option is to print v-rollers that would match the Nut 6 extrusion, but I doubt they would work well.
Maybe we see matching delrin rollers in the future?
-Olaf
Re: Which Alu-extrusion for robotdigg corners and T3P3 delrin rollers? November 25, 2015 06:08AM |
Re: Which Alu-extrusion for robotdigg corners and T3P3 delrin rollers? November 25, 2015 08:32AM |
Re: Which Alu-extrusion for robotdigg corners and T3P3 delrin rollers? November 26, 2015 05:49AM |
Re: Which Alu-extrusion for robotdigg corners and T3P3 delrin rollers? November 26, 2015 06:22AM |
o_lampe
Doug
thanks for clarification.
Do you know the size of the bearing ooznest is using in their v-rollers? If it's OD is 10mm I could just order the rollers ( 1 BRP ) and replace them with my T3P3 rollers.
-Olaf
