Problems with Duet 0.85 motor configuration December 06, 2015 05:16AM |
Re: Problems with Duet 0.85 motor configuration December 06, 2015 06:32AM |
Re: Problems with Duet 0.85 motor configuration December 06, 2015 08:30AM |
; Configuration file for Mini Kossel kit from Think3DPrint3D ; Communication and general M111 S0 ; Debug off M550 PMiniKossel ; Machine name and Netbios name (can be anything you like) M551 Preprap ; Machine password (used for FTP) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P0.0.0.0 ; IP address (0 = use DHCP) M554 P192.168.1.1 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Axis and motor configuration M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high) ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration M665 R105.6 L215.0 B85 H240 ; set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them M92 X80 Y80 Z80 ; Set axis steps/mm M906 X1000 Y1000 Z1000 E500 ; Set motor currents (mA) M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2) M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min) M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute ; Thermistors ;*** If you have a Duet board stickered "4.7K", change R1000 to R4700 to the following M305 commands M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction ;M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds ; Tool definitions M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures ;*** If you have a dual-nozzle build, un-comment the next 2 lines ;M563 P1 D1 H2 ; Define tool 1 ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures M92 E663:663 ; Set extruder steps per mm ; Z probe and compensation definition ;*** If you have an IR zprobe instead of a switch, change P4 to P1 in the following M558 command ;M558 P4 X0 Y0 Z0 ; Z probe is a switch and is not used for homing any axes ;G31 X0 Y0 Z4.80 P500 ; Set the zprobe height and threshold (put your own values here) ;*** If you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here M208 S1 Z-0.2 ; set minimum Z ; T0 ; select first hot end
SENDING:M906 Axis currents (mA) - X:1000, Y:1000, Z:1000, E:500:500:500:500:500:500, idle factor 30And when I tried sending SENDING:G91 G1 S2 X10, I got no feedback from Pronterface, from any of the towers.
>>>G91 G1 S2 X10 SENDING:G91 G1 S2 X10 >>>G91 G1 S2 Y10 SENDING:G91 G1 S2 Y10 >>>G91 G1 S2 Z10 SENDING:G91 G1 S2 Z10
Re: Problems with Duet 0.85 motor configuration December 06, 2015 08:57AM |
Re: Problems with Duet 0.85 motor configuration December 06, 2015 09:14AM |
Re: Problems with Duet 0.85 motor configuration December 06, 2015 01:12PM |
Re: Problems with Duet 0.85 motor configuration December 06, 2015 01:50PM |
