Error in web interface G-Code Console
December 08, 2015 03:27AM
Hi all,
My delta prints fine however, I've regular error message in console.
19:27:01 UTC+11Checksum error on line 830
19:26:43 UTC+11Checksum error on line 827
19:25:43 UTC+11Checksum error on line 815
19:23:13 UTC+11Checksum error on line 782
19:22:43 UTC+11Checksum error on line 77
19:22:29 UTC+11Checksum error on line 77
19:20:55 UTC+11Checksum error on line 743
19:20:35 UTC+11Checksum error on line 73
19:20:27 UTC+11Error: GCodes: Attempt to read a GCode int before a search.
19:19:24 UTC+11Error: GCodes: Attempt to read a GCode int before a search.
19:19:15 UTC+11Checksum error on line 720
19:17:38 UTC+11Checksum error on line 693
19:17:31 UTC+11Error: GCodes: Attempt to read a GCode int before a search.
19:14:09 UTC+11Checksum error on line 645
19:12:52 UTC+11Checksum error on line 628
19:12:38 UTC+11Checksum error on line 624
19:10:28 UTC+11Error: GCodes: Attempt to read a GCode int before a search.
19:10:16 UTC+11Error: GCodes: Attempt to read a GCode int before a search.
Any ideas ?
Have a good day
Re: Error in web interface G-Code Console
December 08, 2015 03:36AM
My guess is that you also have a PanelDue attached and you are getting dropped characters on the serial port. Which firmware version are you using? Try 1.09m-dc42 if you are running an earlier release of my fork.
December 08, 2015 03:53AM
I use 1.09k-dc42 firmware with your last PanelDue firmware PanelDue-5.0-1.13beta1.bin
December 08, 2015 03:55AM
Try upgrading to 1.09m-dc42 and 1.13.
December 10, 2015 06:59AM
Hello,
Duet upgraded to 1.09m-dc42 and PanelDue with 1.13.
always error message in the web console !
Very strange
December 10, 2015 07:10AM
Check that you have this line in config.g:
M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
If you have, try reducing the baud rate from 57600, and set the matching baud rate on the PanelDue settings page.
Edited 1 time(s). Last edit at 12/10/2015 07:12AM by dc42.
December 13, 2015 09:25AM
After upgraded firmware for Duet to 1.09m-dc42 and PanelDue with 1.13 and add M575 P1 B57600 S1 in config.g, I've always errors in Web console !!
Prints are good but web console reports error like
01:21:00 UTC+11Checksum error on line 4628
or
01:25:09 UTC+11Error: GCodes: Attempt to read a GCode int before a search.
Even if printer is online and connected to Web interface but no print in progress, messages on web console are present !
every one or two minutes
Edited 1 time(s). Last edit at 12/13/2015 09:30AM by lolocaledo.
December 13, 2015 01:10PM
Is the PanelDue cable running close to anything that may be generating interference, such as a stepper motor cable?
December 13, 2015 05:19PM
The PanelDue cable is very close to the stepper motor of the extruder.
I moved it and I will say you after some test about results
Thank you
December 13, 2015 06:31PM
Another possibility is that the cable you are using is too thin for its length. If that is the problem, then reducing the baud rate to 38400 will probably fix it.
