Delta preferred tower end stop switches? December 08, 2015 10:50AM |
Re: Delta preferred tower end stop switches? December 08, 2015 12:11PM |
Re: Delta preferred tower end stop switches? December 08, 2015 12:31PM |
Re: Delta preferred tower end stop switches? December 08, 2015 02:22PM |
Re: Delta preferred tower end stop switches? December 08, 2015 02:49PM |
patrickrio
also, I found some super small and cheap magnetic switch items. I think they are too unknown for me to use, but has anyone seen these? could be something to develop for the future.....
Cheap Micro Magnetic Induction Switch, BangGood
Re: Delta preferred tower end stop switches? December 08, 2015 03:02PM |
Re: Delta preferred tower end stop switches? December 08, 2015 05:54PM |
Re: Delta preferred tower end stop switches? December 08, 2015 10:21PM |
Re: Delta preferred tower end stop switches? December 09, 2015 11:59AM |
Re: Delta preferred tower end stop switches? December 09, 2015 04:24PM |
Re: Delta preferred tower end stop switches? December 09, 2015 04:51PM |
Re: Delta preferred tower end stop switches? December 09, 2015 04:54PM |
Re: Delta preferred tower end stop switches? December 11, 2015 07:23AM |
Re: Delta preferred tower end stop switches? December 11, 2015 04:12PM |
Re: Delta preferred tower end stop switches? December 11, 2015 04:42PM |
jaguarking11
...The only down side I had with these is that they are not linear. If you approach from a longer distance they will always triger, but they will not unhook until I exceed the approach. Meaning, if I am at the last 10mm of travel they will trigger at 9mm for arguments sake, but for them to go into off state I have to move the carriage out to 15-20mm before they register as "off" This is not necessarily a con in 99% of how I am using them, however it could be a con for someone somewhere in some rare circumstance.
Re: Delta preferred tower end stop switches? December 12, 2015 06:30AM |
Tower 1:-1,0,0,0,0 Tower 2:-1,0,0,0,0 Tower 3:0,0,0,0,0
Re: Delta preferred tower end stop switches? December 12, 2015 01:38PM |
dc42
You can use those sensors, with two caveats:
1. The minimum supply voltage is specified as 4.5V. So if using them with 3.3V electronics, you need to provide 5V power to them
Re: Delta preferred tower end stop switches? December 13, 2015 09:42AM |
Re: Delta preferred tower end stop switches? December 15, 2015 02:30PM |
dc42
jaguarking11
Some firmwares including RepRapFirmware and Marlin home the printer once at high speed, then move all the carriages down a little and home them again at a slower speed. So all you need to do is increase the amount that the carriages move down if necessary so that the sensors are guaranteed to be not triggered. For RepRapFirmware this is easily done by editing the homedelta.g file on the SD card.
