Solving effector tilt on dual extrusion delta printers June 03, 2015 11:46AM |
Re: Solving effector tilt on dual extrusion delta printers June 03, 2015 12:07PM |
dc42
In using my mini differential IR sensor board, I've become aware that it isn't easy to keep the effector perfectly level as it translates in the XY plane. Any slight difference between the lengths of the diagonal rods in a pair, or the spacing between rods in a pair at the two ends, will cause the effector angle to vary with XY position. There may be other factors I haven't thought of that cause the tilt to vary.
It occurred to me that varying effector tilt will also be a big problem when using a dual-extrusion head such as the E3D chimera. I have a dual extrusion Ormerod printer, and one of the issues is to prevent the non-printing nozzle interfering with the printing nozzle. Even if they are at exactly the same height, the non-printing nozzle leaves slight marks if it passes over filament that just been printed. With varying effector tilt, there will be times when the non-printing nozzle will be slightly lower than the printing nozzle, making the situation worse.
This led me to the following idea. Suppose we deliberately tilt the effector so that the non-printing nozzle is higher than the printing nozzle? Consider the following setup. The effector carries two nozzles, one offset from the centre in the +X direction, the other offset in the -X direction. On the Z carriage slider, we use a small servo, or two solenoids, or a voice coil, or some other mechanism to rotate the carriage by a few degrees about the Y axis, thereby changing the relative heights of the two diagonal rod bearings. This will in turn cause the effector to rotate about the Y axis, raising one of the nozzles above the other.
This approach could be generalised to more than two nozzles, but depending on the arrangement of the nozzles on the effector, it may be necessary to rotate two or all three of the carriages.
Re: Solving effector tilt on dual extrusion delta printers June 03, 2015 12:56PM |
Re: Solving effector tilt on dual extrusion delta printers June 03, 2015 01:49PM |
Re: Solving effector tilt on dual extrusion delta printers June 03, 2015 01:55PM |
dougal1957
Dave
How would fine positioning work?
Could you use a High Quality Servo and use PWM to fine set the positioning something like a good digital servo with metal gears would have to have extremely good holding torque tho.
Like the concept tho but maybe a beam with F623 bearing's one from each side just to help hold lateral positioning?
Doug
Re: Solving effector tilt on dual extrusion delta printers June 03, 2015 02:19PM |
Re: Solving effector tilt on dual extrusion delta printers June 06, 2015 08:31PM |
Re: Solving effector tilt on dual extrusion delta printers June 07, 2015 02:56PM |
Re: Solving effector tilt on dual extrusion delta printers July 03, 2015 06:15AM |
Re: Solving effector tilt on dual extrusion delta printers July 03, 2015 09:42AM |
Re: Solving effector tilt on dual extrusion delta printers July 07, 2015 10:09AM |
Re: Solving effector tilt on dual extrusion delta printers July 11, 2015 06:42AM |
Re: Solving effector tilt on dual extrusion delta printers July 11, 2015 08:25AM |
Re: Solving effector tilt on dual extrusion delta printers December 15, 2015 12:54PM |
dc42
I have a dual extrusion Ormerod and have never had a problem with oozing from the inactive nozzle, using PLA filament, 10mm retraction (the slic3r default), and 150C standby temperature. So I think I ll stick to my plan, which keeps the weight of the actuator mechanism off the effector.
