Trouble with larger prints sticking January 01, 2016 02:08PM |
Re: Trouble with larger prints sticking January 01, 2016 02:48PM |
Re: Trouble with larger prints sticking January 01, 2016 03:44PM |
Re: Trouble with larger prints sticking January 01, 2016 10:47PM |
Re: Trouble with larger prints sticking January 02, 2016 02:32AM |
Re: Trouble with larger prints sticking January 02, 2016 01:48PM |
Re: Trouble with larger prints sticking January 02, 2016 03:19PM |
Re: Trouble with larger prints sticking January 02, 2016 04:46PM |
Re: Trouble with larger prints sticking January 04, 2016 12:11PM |
Re: Trouble with larger prints sticking January 04, 2016 06:52PM |
Re: Trouble with larger prints sticking January 05, 2016 02:41AM |
Ace67aod
I am currently working on compensating for the differences in trigger height i am measuring then working the results in the H parameter inside the G30 commands in my bed.g file. I am using the difference between my (Z trigger height set point) - (Actual measured trigger height at Probe points). Please correct if i am wrong
G30 P8 X36.8 Y32 Z-99999 H0.00 Is this the correct?
Re: Trouble with larger prints sticking January 05, 2016 06:28AM |
Re: Trouble with larger prints sticking January 05, 2016 08:02PM |
Re: Trouble with larger prints sticking January 05, 2016 11:01PM |
Re: Trouble with larger prints sticking January 17, 2016 10:35PM |
Re: Trouble with larger prints sticking January 18, 2016 03:39AM |
Re: Trouble with larger prints sticking January 18, 2016 05:55PM |
Re: Trouble with larger prints sticking January 18, 2016 06:22PM |
Re: Trouble with larger prints sticking January 18, 2016 06:43PM |
Re: Trouble with larger prints sticking January 18, 2016 06:59PM |
Re: Trouble with larger prints sticking January 18, 2016 07:27PM |
Re: Trouble with larger prints sticking January 22, 2016 12:07AM |
Re: Trouble with larger prints sticking January 22, 2016 03:00AM |
Ace67aod
When i adjust for this by adding the H parameter this makes things worse because i have to add a lot more than just the probe difference for the nozzle to be low enough to squish the first layer (or even be close enough to stick the plastic to the PEI) which then throws off the rest of the leveling
Ace67aod
*If this is effector tilt would magnetic rods prove to be a solution?
Re: Trouble with larger prints sticking January 30, 2016 05:10PM |
Re: Trouble with larger prints sticking January 30, 2016 05:20PM |
Ace67aod
I must be doing other things wrong because i have done all this and the result is usually a perfect skirt but then the inside of the print wont even stick i just get a ball of plastic at the nozzle. Could I not be snagging my paper correctly? how tight does the nozzle need to grab the paper? Would this even make a difference?
Re: Trouble with larger prints sticking January 30, 2016 05:51PM |
Re: Trouble with larger prints sticking January 31, 2016 03:40AM |
Re: Trouble with larger prints sticking January 31, 2016 09:33PM |
Re: Trouble with larger prints sticking February 06, 2016 03:56PM |
Re: Trouble with larger prints sticking February 07, 2016 09:50PM |
Ace67aod
So after i remeasure and compensate with the H parameter then i check zero after an auto-cal my paper snags at zero but HARDLY snags... So it seems almost as if this is still not enough to squish the first layer (usually only in the middle the skirt prints fine) is there something else i could be missing to make this happen?
