Kossel mini carriage roller problem. January 09, 2016 12:25PM |
Re: Kossel mini carriage roller problem. January 09, 2016 12:38PM |
Re: Kossel mini carriage roller problem. January 09, 2016 01:15PM |
Re: Kossel mini carriage roller problem. January 09, 2016 02:46PM |
Re: Kossel mini carriage roller problem. January 10, 2016 12:13AM |
Re: Kossel mini carriage roller problem. January 10, 2016 01:00AM |
Re: Kossel mini carriage roller problem. January 10, 2016 03:34AM |
Re: Kossel mini carriage roller problem. January 10, 2016 04:05AM |
Re: Kossel mini carriage roller problem. January 10, 2016 04:19AM |
Re: Kossel mini carriage roller problem. January 10, 2016 08:06AM |
tuxhead
Hi @xile6,
>You can try an lossen the tension bolt on the side.
> Also i check the pics again. And there shouldnt be a nut on that right wheel.
> All 3 should be carriage, wheel, nut.
> You have on the right side carriage, nut wheel ,nut.
The earlier pics were set of few iterations I tried to level the tilts. I also had tried "carriage->wheel->nut" assembly which yields a same result (pics attached). It was the first thing I did when the problem was discovered. In the pictures, looking closely, when the carriage is attached to the extrusion, the lower right half (the U-shaped end) actually raises up a bit which seems to add the tilt. There are actually no tensioner action added to the whole assembly (which itself it pretty tight to roll on the rails), The screw on the right is just a dummy, actually the tensioner side hole too, is pretty loose to fit M3s properly and there are no bolts or thread taps inside it to tighten it (but they carriage has a slot hole to insert a M3 nut for the tensioner bolt which is not added at the moment) .
Cheers,
Arvind.
Re: Kossel mini carriage roller problem. January 11, 2016 09:49AM |
tuxhead
Hi @xile6,
Cheers,
Arvind.
Re: Kossel mini carriage roller problem. January 11, 2016 11:38AM |
Re: Kossel mini carriage roller problem. January 11, 2016 10:48PM |
tuxhead
> Your 2020 extrusion look to be approx. 6.4mm centre space width so work with roller of 7mm thickness. For the adjusting tension function requires M3 screw and two M3 nuts. Some pictures of the built up units
@win3d , good point, after visiting the link posted, I tried measuring the spacing and roller width, which unfortunately seems to match up the dimensions. Caliper reading indicates the center spacing of extrusion is around 6.24mm while the roller thickness appears to be 7mm approx. (images attached)
Re: Kossel mini carriage roller problem. January 12, 2016 12:14PM |
Re: Kossel mini carriage roller problem. January 12, 2016 12:18PM |
Re: Kossel mini carriage roller problem. January 13, 2016 11:19AM |
tuxhead
Also the rollers I have takes M5 screws to fit in properly. Is it a right one so far anyone uses in their setups?
Cheers,
Arvind.
Re: Kossel mini carriage roller problem. January 14, 2016 05:08AM |
Re: Kossel mini carriage roller problem. February 29, 2016 11:47AM |
