Delta Firmware - Adjusting for Effector Tilt February 11, 2016 11:41PM |
Re: Delta Firmware - Adjusting for Effector Tilt February 12, 2016 02:15AM |
Re: Delta Firmware - Adjusting for Effector Tilt February 16, 2016 03:14AM |
Re: Delta Firmware - Adjusting for Effector Tilt February 16, 2016 06:19PM |
dc42
RepRapFirmware allows the probe point heights to be corrected to allow for variations in the probe trigger heights, and I think Repetier has some sort of height correction facility too; but AFAIK Marlin doesn't. So I think you need to remove the effector tilt, or move the probe closer to the nozzle to reduce the effect of tilt, or calibrate manually.
nebbian
If you're interested in removing effector tilt then this might help:
Make a piece up like this, and clamp it to your effector. The bottom should stay flat on the build plate as you move the effector around over the surface. You need to do this for each of the 3 pairs of diagonal rods.
Space out either the effector end, or the carriage end depending on which way the tilt changes as you move the effector. It's easy to see how much tilt there is with this system, and if you get the ends to within a mm difference then the difference between your nozzle and sensor will be many times less than that. In fact with this system it's easy to get the difference down to 0.1mm or so, which means the difference between sensor and nozzle will be less than a p00fteenth (technical term).
[attachment 72643 tiltmeter.jpeg]
Re: Delta Firmware - Adjusting for Effector Tilt February 16, 2016 06:22PM |
Re: Delta Firmware - Adjusting for Effector Tilt February 16, 2016 08:10PM |
EvilBetty
The thinnest M3 washers I can find are all 0.5mm in thickness. (Found some fancy anodized ones that are thinner, but cost prohibitive)
What do you recommend as an alternative for shims that might go as low as 0.1mm?
Re: Delta Firmware - Adjusting for Effector Tilt February 17, 2016 02:34AM |
Re: Delta Firmware - Adjusting for Effector Tilt February 17, 2016 11:14AM |
Re: Delta Firmware - Adjusting for Effector Tilt February 23, 2016 01:29AM |
Re: Delta Firmware - Adjusting for Effector Tilt February 23, 2016 02:47AM |
paveldvor
Hi, i see you have aluminium buildplate - is it any good, how does PLA and ABS stick on it?
Re: Delta Firmware - Adjusting for Effector Tilt February 23, 2016 02:51AM |
Khalid
EvilBetty, Can you post the configuration.h file
