Replace traxxas end with sprung ball bearing joints?
April 28, 2016 05:50AM
Looking for links to projects and/or cad files. Cannot find anything in forums but I know I have seen posts before, I don't know the correct search terms I think.
Re: Replace traxxas end with sprung ball bearing joints?
April 28, 2016 06:05AM
search for Cherry Pi
April 28, 2016 08:00AM
Thanks, that was what I was looking for.
PRZ
April 28, 2016 10:49AM
Also these (D-Box and Lily), with twin wires.
D-box : Dyneema wire (50 kg ?)
Lily : Nylon wire 16 kg
Even with these wires near the balls, due to the wire tension there is a tendancy to deform the effector and if you have a heated bed, the Effector material shall be adapted to hot temperature (ABS or polycarbonate).
My PETG effector did not survived a heat bed at 120°C and chamber at 60°C. It shall be reprinted in ABS or Polycarbonate
Good wire tension improve precision and create a friction which may eliminate banding (it did for both machines).
Pierre
- Safety [reprap.org]
- Embedded help system for Duet and RepRap Firmware [forums.reprap.org]
- Enclosed delta printers Lily [rouzeau.net] and Lily Big [rouzeau.net]
- OpenScad delta printer simulator [github.com]
- 3D printing on my site [www.rouzeau.net]
April 28, 2016 12:33PM
Great, the more the better. Thanks
