Showing off - Video of my Mega Delta printing CNC parts in PLA June 04, 2016 09:40AM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 04, 2016 10:38AM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 04, 2016 11:26AM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 05, 2016 12:35PM |
aussiephil
deckingman
Nice one ! Don't suppose you are anywhere near Canberra are you?
Depends if you consider Flynn to be in Canberra.....
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 05, 2016 08:18PM |
deckingman
aussiephil
deckingman
For a Brit, it's in the ACT so that's near enough. My daughter moved out there a couple of years back to be with her Kiwi boyfriend. They were in in Gungahlin but have recently move to Casey. They are getting married in September so I'll be out there for a couple of weeks for the wedding. It'd be good to see your printer in the flesh but thinking about it, I doubt if I'd get a pass. It could end up being a dual ceremony - one wedding and one divorce.
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 06, 2016 01:07PM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 06, 2016 09:00PM |
deckingman
Is it OK if I PM you?
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 07, 2016 06:52AM |
aussiephil
Surprised that the video hasn't raised questions or comments in general.
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 07, 2016 07:47AM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 07, 2016 10:35AM |
deckingman
aussiephil
I'm not. If it'd been a pile of crap you'd have had plenty of comments. As there is nothing to criticise, there are no comments. Take it as a compliment. (Sorry, that's just an old man getting more cynical every day).
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 07, 2016 10:42AM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 07, 2016 10:08PM |
deckingman
aussiephil
Careless
looks awesome.
what was the total cost of the system? (if you've been keeping track, that is... I know sometimes it gets out of hand and you just forget about keeping track lol)
BuildAThing
Aussiphile,
I read all of your build thread and I think your Delta has turned out amazing! I hope to build a Delta soon and yoursee is an inspiration!
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA June 08, 2016 04:37AM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA July 09, 2016 02:07PM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA July 10, 2016 12:34AM |
eflin1
Great build thread , I ´m impressed , I´m planning to build a simular sized Delta based on the german hexagon delta basics, however your design makes me rethink that route. So are you still planning to continue with that design version 2 ?
What made you decide to not go for a linear Hiwin carriage design ? aren´t such long rods (even 20 mm ones ) kind of risky regarding their straightness ? Why no Vulcano 0,8 to 1.0 mm nozzle with this kind of big-build space ?
anyway my compliments !!
Eflin
(lübeck germany)
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA July 11, 2016 06:02PM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA July 12, 2016 10:03PM |
shadowphile
That is some really nice printing and engineering, congratulations! You have inspired in me that my biggy-Kossel build can give higher performance.
Duet running on a 1M tall 350mm bed with 300 build zone, 300mm 500W silicone heater under 3mm borosilicate glass, black thermally-conductive double-sticky tape from heater to glass, no heat spreader (I could not get high enough temps using a spreader), nema 23 motors, 20x20 towers, extruded aluminum vertex pieces from Robotdigg, 80mm-spaced rods, 3mm filament with a geared-down stepper, some simple Bowden-tube strain-relief such as yours.
thanks
shadowphile
1) How accurate is your build? I have been trying to square, etc my system but getting (repeatable!) measurements of both ends of the rod spacing, tower squareness, etc below 0.2mm or so has been hard with just a 6" digital caliper. (I borrowed a long caliper from work but only for the original construction).
shadowphile
2) How is your bed stackup? I keep sticking with a glass bed because it is impervious and perfectly flat and really popular and inexpensive, but it has been difficult to heat properly and also mount solidly. You have a metal bed: is the silicone pad just sticking underneath with the usual adhesive that comes on them? How is the bed supported on the frame? This has been a nightmare for me because my silicone pad has a bump where the cable exits, making it hard to get a flat build out to the edge of the bed. But the tape gets soft when hot and the suspended heater pad starts to pull away, so I have cork and cardboard insulation then another metal plate. I wanted to mount the glass bed directly to the frame so now everything underneath is suspended and I have to put a light bed support under the middle, blegh!
I'm using LM20UU linear bearings with the carraiges/rods and my test of both smoothness and alignment is to place the carraige at the top of the rod pair and let it fall to the bottom under it's own weight (not attached to belt), I've seen no sign of jerkiness indicating that rod spacing is good and bearings are correctly lubricated and smooth. Straight from the factory they were crap and needed to re-lubed.Quote
shadowphile
3) Do the printed carriages slide ok on the steel rods? How do you keep the friction down? I also keep trying to use wheel-bearing-mounted carriages but that has also been a pain with warpage because printed carriages with wheels just warp too much; I have been using some polycarbonate plates to stiffen them. With my frame design I have to use the 20x20 towers as the rails.
Answered somewhere above but they are 2040 t-slot.Quote
shadowphile
4) You have printed vertex parts? What are your horizontal beams?
At this time of the year the ambient temperatures are under 20c, I doubt i could get away with even printing PLA in summer when it goes above 40c in the same area...Quote
shadowphile
5) With those print speeds and heated bed and no cooling, how does not print not slump? I just built in a fan-shroud to direct air just under the nozzle and now I feel that may have been a waste of time, sigh.
Hopefully I've given you some ideas. Yes mine is essentially all custom parts.Quote
shadowphile
After looking at your design choices I feel like I am back to square one, but I see a lot of custom parts on your setup and that flying extruder, as clunky as it looks, must help a lot with print-speed and quality. I'm still not convinced the performance of a normal Bowden setup can be fully compensated by just increasing the retraction settings, especially with jam-prone PLA, but you do it fine even at 90 cm/sec! I tend to stay around 30.
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA July 19, 2016 08:19AM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA July 27, 2016 01:52AM |
DjDemonD
Looks like a great printer. I'm a big advocate of flying extruder and have designed (using the term loosely) a bracket for a titan extruder. Yours does seem to wobble about a lot but perhaps this doesn't show in the prints as the effector and arms have much more mass than a little kossel mini. The normal scheme isn't going to work though as the rods are long and the extruder would be quite a way above the hotend meaning a much longer bowden tube. Why not just mount the titan as a direct extruder since its not really suspended the way you have it configured anyway?
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA August 22, 2016 06:08PM |
Re: Showing off - Video of my Mega Delta printing CNC parts in PLA September 29, 2016 09:43AM |
