MGN12H and kossel metal carriages July 12, 2016 08:59AM |
Re: MGN12H and kossel metal carriages July 12, 2016 10:31AM |
Re: MGN12H and kossel metal carriages July 12, 2016 10:47AM |
Re: MGN12H and kossel metal carriages July 12, 2016 10:54AM |
Re: MGN12H and kossel metal carriages July 12, 2016 11:05AM |
DjDemonD
Also when using thinkyheads delta simulator it suggests arm lengths of around 500mm for a 1000m tall delta with 300mm bed. This puts them 200mm longer than David's large delta (which I am using as a guide). How long should I be aiming for? In David's guide the arms are 315mm plus the rod ends? I presume this works so why the discrepancy?
Re: MGN12H and kossel metal carriages July 12, 2016 11:13AM |
Re: MGN12H and kossel metal carriages July 12, 2016 01:57PM |
Re: MGN12H and kossel metal carriages July 23, 2016 11:57AM |
Re: MGN12H and kossel metal carriages July 26, 2016 07:59AM |
Re: MGN12H and kossel metal carriages July 26, 2016 08:17AM |
Re: MGN12H and kossel metal carriages July 26, 2016 08:21AM |
Re: MGN12H and kossel metal carriages July 26, 2016 11:37AM |
Re: MGN12H and kossel metal carriages July 26, 2016 01:18PM |
Re: MGN12H and kossel metal carriages July 26, 2016 02:19PM |
Re: MGN12H and kossel metal carriages July 30, 2016 06:12AM |
Re: MGN12H and kossel metal carriages September 11, 2016 07:12AM |
Re: MGN12H and kossel metal carriages September 11, 2016 08:35AM |
Re: MGN12H and kossel metal carriages September 11, 2016 04:45PM |
Re: MGN12H and kossel metal carriages September 11, 2016 07:04PM |
Re: MGN12H and kossel metal carriages September 12, 2016 01:53AM |
Re: MGN12H and kossel metal carriages September 13, 2016 04:51PM |
And those original carriages run smooth enough to fall out even with no load on them. For the belts, I chose not to go for the 'normal' way of tensioning the belts as kossel does. It seems stupid to me to sort of skew the whole frame to tension the belts
I'd rather built the frame completely symetrical and use other means to tension the belts.|
Re: MGN12H and kossel metal carriages September 13, 2016 06:16PM |
Re: MGN12H and kossel metal carriages September 17, 2016 10:08AM |
Re: MGN12H and kossel metal carriages September 17, 2016 11:45AM |
Re: MGN12H and kossel metal carriages September 17, 2016 07:03PM |
Re: MGN12H and kossel metal carriages September 18, 2016 01:40AM |
Re: MGN12H and kossel metal carriages September 19, 2016 01:48PM |
Working on designing the fan ducts, sort of getting done. They won't be extremely pretty but hopefully functional
Re: MGN12H and kossel metal carriages September 19, 2016 03:17PM |
