I will try to help, but it looks really messed up.
First, you need to make sure that you have the right measurements in. Measure the smooth rod, diagonal rod, carriage, bed, effector, ....everything. Make sure the numbers match. Google each item to find what it is, and get as close as you can.
Chances are, that they have the wrong number.
Secondly, make sure the bed is centered. The kit I got, you could not center the bed between the xyand z. And this caused the head to try to reach a part of the bed that was not there.
And recheck every screw.
