Kossel mini not printing straight lines. September 10, 2016 07:32PM |
Re: Kossel mini not printing straight lines. September 10, 2016 10:22PM |
Re: Kossel mini not printing straight lines. September 10, 2016 10:57PM |
Re: Kossel mini not printing straight lines. September 10, 2016 11:26PM |
Re: Kossel mini not printing straight lines. September 11, 2016 09:42PM |
Re: Kossel mini not printing straight lines. September 11, 2016 11:47PM |
nebbian
SilverBullet,
Welcome to deltas. They are frustrating, and often difficult to get to print straight.
It's unlikely to be missing steps. More likely is one or more of the following:
* Towers not parallel
* Towers twisted
* Bed not at 90 degrees to the towers
* Diagonal rod value in firmware not matching physical measurement
* Delta radius in firmware not matching physical measurement
* Rod end distance different between carriage and effector (causing effector tilt at different areas of the bed)
Those are the usual suspects on a delta, good luck finding the issue.
Re: Kossel mini not printing straight lines. September 12, 2016 12:59AM |
Re: Kossel mini not printing straight lines. September 12, 2016 01:20AM |
Re: Kossel mini not printing straight lines. September 12, 2016 04:21AM |
Re: Kossel mini not printing straight lines. September 13, 2016 06:00AM |
silverbullet
nebbian
SilverBullet,
* Towers twisted
I've checked and rechecked all those things, that's why it is doing my head in. There is physically nothing i can find wrong, corner to corner measurements are spot on and towers are square to the bed which i used a brand new Lufkin builders square to check with.
Your not wrong about them being difficult, as much as i want to throw the towel in on the delta part of me wants to keep going for the prize and somehow work things out
Re: Kossel mini not printing straight lines. September 13, 2016 07:18AM |
Re: Kossel mini not printing straight lines. September 13, 2016 10:47AM |
Re: Kossel mini not printing straight lines. September 13, 2016 12:24PM |
Re: Kossel mini not printing straight lines. September 13, 2016 03:23PM |
Re: Kossel mini not printing straight lines. September 16, 2016 07:59AM |
