Hi there,
Is there somewhere a list of extruders that are currently on the market that can be used with a bowden setup in a delta printer?
So far I know of the brandless cheap not-geared metal extruder: [
www.123-3d.nl]
The bondtech extruder: [
shop.bondtech.se]
Titan Extruder: [
reprapworld.nl]
And then I'v seen several 'custom' designs on thingiverse etc. that you can print, but I find it hard to judge the quality of those and gather all the metal parts that are needed to build those. I'd rather spend a little more money and get an easy to build kit that I know in advance will work well.
So far the bondtech seems attractive to me: a 1/3 gearing system and 2-sided bolts for better grip... but it's so expensive.
Are there any alternatives that use a similar system and can be bought as a kit or pre-assembled, but less expensive?
Edited 2 time(s). Last edit at 09/11/2016 05:35AM by BramV.
