Struggling to identify problem. September 29, 2016 12:14PM |
Re: Struggling to identify problem. September 29, 2016 05:13PM |
Re: Struggling to identify problem. September 29, 2016 05:54PM |
Re: Struggling to identify problem. September 29, 2016 08:14PM |
Re: Struggling to identify problem. September 29, 2016 09:28PM |
Re: Struggling to identify problem. September 29, 2016 09:54PM |
Re: Struggling to identify problem. September 29, 2016 10:49PM |
Re: Struggling to identify problem. September 30, 2016 06:23AM |
Re: Struggling to identify problem. September 30, 2016 10:44AM |
Re: Struggling to identify problem. September 30, 2016 11:09AM |
hercek
100.18 steps per mm is a strange value, I would almost say that you have somehow faulty belts.
Re: Struggling to identify problem. September 30, 2016 11:19AM |
feistylemur
I've been playing around with it tonight. I tried that eschertek calculator and it was disastrous. I don't know what I was doing wrong but it was giving me values for the Z offset in the completely wrong direction.
Re: Struggling to identify problem. September 30, 2016 11:48AM |
Re: Struggling to identify problem. September 30, 2016 02:34PM |
nebbianI've measured similar on both my printers. If you haven't measured the belts then you might be in for a surprise. I'm convinced that normal GT2 belt is designed for much higher tensions than we normally run it at, so that it stretches to the 2mm per tooth value that everyone thinks it is. I've consistently measured it to be around 0.2 - 0.3% undersize.Quote
hercek
Re: Struggling to identify problem. October 01, 2016 12:04AM |
dc42
feistylemur
Most likely you entered the height errors with the wrong sign. I state in the instructions that you need to enter a positive height error where the nozzle is too high and a negative height error where it is too low, but still some people seem to enter them the other way round and then wonder why the results diverge instead of converging.
Re: Struggling to identify problem. October 01, 2016 12:23AM |
Re: Struggling to identify problem. October 01, 2016 06:45AM |
I looked at dc42's calibration web page. It does not seem to support different lengths for the diagonal rods. Therefore you cannot expect it to properly calibrate your printer when one tower has about 0.5 mm different diagonal rods from the other two towers. You have two options:Quote
feistylemur
Meaning along each tower axis the nozzle rises from 0.1 to 0.25 by the time it reaches the farthest point from the tower (X and Z are .1 y is .25), no matter how many times I run it. I have to guess this could be due to rod length error, and dimensional error perhaps in the effector itself given how poorly printed it is.
Re: Struggling to identify problem. October 01, 2016 11:11AM |
hercek
It is actually quite easy to measure the belt length precisely when you can already print (the bed is leveled with possibly bad steps per mm). Print something and measure with calipers whether the height is right.
Maybe you need to tighten them a bit more ... hopefully the idler will not tear away. The belts are supposed to produce a nice bass tone when plucked
Re: Struggling to identify problem. October 01, 2016 12:32PM |
Re: Struggling to identify problem. October 01, 2016 01:57PM |
Re: Struggling to identify problem. October 01, 2016 07:24PM |
Re: Struggling to identify problem. October 02, 2016 05:26AM |
Re: Struggling to identify problem. October 07, 2016 07:06PM |
Re: Struggling to identify problem. October 09, 2016 08:48AM |
Re: Struggling to identify problem. October 11, 2016 11:41AM |
Re: Struggling to identify problem. October 11, 2016 05:11PM |
Re: Struggling to identify problem. October 11, 2016 06:14PM |
