Kossel XL - Motor & endstop issues
November 11, 2016 06:58AM
Hi Fellow Nerds,
I've been having issues with my nema 17 steppers in combination with RAMPS 1.4
[www.youtube.com]
It just started out of nowhere, the unwillingness to do a decent G28.
Looks like a faulty connection issue to me?
Re: Kossel XL - Motor & endstop issues
November 11, 2016 09:51AM
I prefer geek. It could be a lot of stuff, do your endstops work? What response do you get from m119?
What controller and firmware are you using?
Simon Khoury
Published:Inventions
November 12, 2016 05:55AM
Dear fellow geek,
I'm using Ramps + arduino mega with marlin v1.1
My endstops used to work perfectly.
When I use M119 i get:
TRIGGERD when the carriages touch it & OPEN when they don't
November 12, 2016 06:32AM
Thats odd can you post your configuration.h? It doesn't seem to be responding to the endstops, just crashing the carriages.
Simon Khoury
November 14, 2016 09:08AM
This is the config file i use.
thanks in advance!
open | download - Configuration.h (56.4 KB)
November 14, 2016 11:32AM
A couple of things might help. Change them one at a time, it would be nice to see what it was.
#define HOMING_FEEDRATE_Z (200*60)
Your homing feedrate is very high 12000 mm/min. Not saying you can't home at that speed but that's pretty drastic. Try 2000 (34*60).
Are you running 24v for your stepper motors or 12v, these kinds of speeds at 12v are a bit of push.
Also some people have had more success with the following workaround (it might be a bug):
Where it says:
#define Z_MAX_POS MANUAL_Z_HOME_POS
instead put
#define Z_MAX_POS 298.15
Hope this helps.
Simon Khoury
November 16, 2016 09:48AM
Wow,
it worked!
I never believed it would, but it really did! Thank you so much. I was about to throw my printer out ( after numerous random incidents like this )
thumbs up
November 16, 2016 09:52AM
No problem. Which of the changes was the one that worked?
Simon Khoury
November 17, 2016 06:30AM
I changed the code
Where it says:
instead put
I also adjusted the homing Speed like you suggested.
I have 12v for the steppers.
