mga
Err: MINTEMP in a delta Kossel printer
December 29, 2016 07:34AM
I have a Kossel delta changed. I mounted an extruder 3 in 1. When I turn are read two strange temperature: 22 ° is on the heatbed and on the extruder. Since the minimum temperature should be 5 ° I do not know what it is. I checked all the single connections.
Re: Err: MINTEMP in a delta Kossel printer
December 29, 2016 10:59AM
A MINTEMP error is a sign for a shortcut in the thermistor wires. Often it is the setscrew pushing to hard against the sensor or the ptfe tubes on the sensor wires are not intact.
mga
January 02, 2017 09:47AM
I do not think my case if I unplug the thermistor does not read anymore, but if I see riconnetto 22 ° is on the hot bed that on the thermistor. Perhaps it is a firmware error, but do not know how to correct it
January 02, 2017 04:17PM
If you read 22° on both thermistor inputs ( bed and hotend ) but only have one thermistor attached, it is a shortcut between the sensor input pins.
mga
January 03, 2017 08:06AM
I have two thermistors and both correctly read the temperature with slight variations from one another, but still get the error MINTEMP inexplicably. And the printer for this reason work not.
