Printer moving really slow
Posted by BilliBob
December 31, 2016 06:42PM
I'm having trouble with some of the firmware for my Kossel. My hardware is based from a Arduino Mega2560. I have attached 2 different Marlin firmwares which I've tested and gotten to work each in different aspects.
The file titled Marlin-AC is the firmware I am trying to make work, the problem is that when the printer tries to move it does so extremely slowly at a rate of maybe 0.5mm/s or possibly less. The firmware titled Marlin doesn't have the movement problem but I cant get the heating to work properly and the UI seems to be missing aspects relevant to heated bed control as well.
Can anyone determine the difference between these 2 codes which is causing this problem in the Marlin-AC? Or know how to fix the issue outright?
Thanks,
Steven
open | download - Marlin-AC.zip (269.4 KB)
open | download - Marlin.zip (484.5 KB)
Re: Printer moving really slow
January 01, 2017 09:51AM
They look OK. Perhaps the eeprom has some funny settings in it when you're using the AC version (AC has eeprom enabled, but Marlin doesn't).
Try entering
M502
M500
in Pronterface, which will reset the eeprom settings to what's in the file.
Edited 1 time(s). Last edit at 01/01/2017 09:52AM by nebbian.
January 01, 2017 10:41AM
Thank you so much that fixed the problem outright.
