Hello all, I have an issue. Recently, I bought the FLSUN Kossel Delta kit. I have it all set up and connected to my PC, but when I upload the Marlin firmware and use the G28 command in Repetier Host, only my Y and Z axes go to their home location. Running M119 shows that the X endstop is triggered, but even after unplugging the switch it still says it is triggered. I had this issue earlier but reflashing the firmware solved it, but then I realized my endstops were not equidistant from the top frame, so I moved the X endstop and now I have the issue all over again. I've scoured Google and cannot find anything that helps, or something I can even make sense of as I have no idea what I am doing when it comes to Arduino. After some testing, I've narrowed it down to the fact that either the connector for the X endstop isn't connecting well with the plug, or the switch itself is busted. The latter doesn't make sense though, as I had it working earlier. I also tested the switch with a ohmmeter for resistance and there was a connection so the switch is not broken. That leads to only the plug. I just have no idea how to test it. Any help?
Pastebin of Marlin configuration.h: [
pastebin.com]
Edited 1 time(s). Last edit at 01/02/2017 11:15AM by Pyro_Llama.
