Micromake not quite reaching the bed to print.
Posted by Focussys
January 14, 2017 11:22AM
Just upgraded my Micromake Delta from Arduino Mega/Ramps 1.4 to Micromake's own Makeboard Pro.. Uploaded the same firmware as before and everything works exactly as before except: Having done the autobed level in Cura's Machine Debugger (now 0.06mm accurate) it prints about 3mm above the bed.
I use Mattercontrol, so should be able to adjust it downwards as before with a negative number, but it won't go any lower. I have checked the firmware accepts negative Zs.
Any ideas?
Re: Micromake not quite reaching the bed to print.
January 15, 2017 09:08AM
You need to adjust the Z probe height in firmware.
Edited 1 time(s). Last edit at 01/15/2017 09:08AM by nebbian.
