Building a Kossel: Need advice on final parts January 26, 2017 07:04AM |
Re: Building a Kossel: Need advice on final parts January 27, 2017 04:27PM |
Re: Building a Kossel: Need advice on final parts January 27, 2017 06:21PM |
Re: Building a Kossel: Need advice on final parts January 27, 2017 06:38PM |
Re: Building a Kossel: Need advice on final parts January 27, 2017 06:43PM |
Re: Building a Kossel: Need advice on final parts January 27, 2017 06:54PM |
Re: Building a Kossel: Need advice on final parts January 27, 2017 07:03PM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 04:25AM |
Riggi
That is another possibility indeed. I'll do some searching to see if the Robotdigg rails are good enough or not and assemble a list for all the Robotdigg parts without the electronics and hotend. Do you happen to know wether or not the Robotdigg extruded profiles work with V-rollers or are the linear rails in general better than the V-rollers? I've read a lot of mixed thoughts about V-rollers so far.
Re: Building a Kossel: Need advice on final parts January 28, 2017 04:29AM |
Riggi
That's true. I'll look around where I can get the parts in the EU as it would probably be cheaper.
Thanks for the suggestion!
Re: Building a Kossel: Need advice on final parts January 28, 2017 05:33AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 06:35AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 06:56AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 06:58AM |
Riggi
Okay thanks dc42! I'll see if I can get my hands on some good linear rails instead then.
I've also found an alternative to the Robotdigg vertices, which are these metal brackets [www.amazon.com]. Do you think they offer the same stability to the build like the Robotdigg ones? The robotdigg carriages really look like a clean solution for an open belt but are they really that much better compared to the 3D printed variants?
Re: Building a Kossel: Need advice on final parts January 28, 2017 07:07AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 07:21AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 08:35AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 08:54AM |
DjDemonD
The rails do not make any noise at all that I can hear, with Duetwifi and high microstepping, I can hear my hotend fan more than any other component.
Titeuf007
Couple of things strike me about your build list:
E3d v6 direct - you will surely want a bowden version, even if you use flying extruder there is still a bowden tube. Plus if you buy bowden and go direct no problem.
The brackets I bought which were the Chinese copies of robotdigg, had idlers for 6mm belts with them.
The horizontals at the base 6x 2020 works as it leaves you a 20mm gap for wiring etc...
For the top horizontals given your printer's size I would buy 2040's.
Igus rails are probably very nice but I've not come across many people using them on 3d printers, and they will have more friction when starting from stopped than versions with ball bearings.
Re: Building a Kossel: Need advice on final parts January 28, 2017 09:03AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 09:09AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 10:27AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 10:33AM |
Riggi
Okay it's good to hear that they barely make any noise. The 3D printer would be put in my room and I wouldn't want it to be very noisy all the time.
And oh so that's why you have so many different extrusions in your part list dc42. When I went over it, I was confused as to why you had that many different sizes of extrusions. It all makes sense now and it's pretty neat! Also, at what kind of size would you recommend 2040 extrusions over 2020 extrusions for the vertical extrusions? The Robotdigg XL vertical extrusions are only 2020 and are 750mm long and I'm not sure if they'll be sturdy enough.
Re: Building a Kossel: Need advice on final parts January 28, 2017 10:42AM |
dc42
Riggi
When I build my delta, Robotdigg only sold the 2020 vertices. If I was starting now, I would use 2040 because the extra cost is small. I haven't had any issues that I can blame on using 2020 instead of 2040.
Re: Building a Kossel: Need advice on final parts January 28, 2017 11:55AM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 12:48PM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 01:13PM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 01:20PM |
Re: Building a Kossel: Need advice on final parts January 28, 2017 01:42PM |
Riggi
I'm still rather picky about the carbon fiber rod ends. I've read some mixed results about magnetic joints in general, but actually quite a lot of good stuff about Hayden's magnetic joints. Sadly they are quite expensive and I don't think they will fit on the Robotdigg carriages. I've read on your blog David that you're using Igus joints over the Traxxass joints. Are they a big improvement over the Traxxas joints or do you think it's better to go for a different kind of joint?
Re: Building a Kossel: Need advice on final parts January 28, 2017 02:15PM |
Re: Building a Kossel: Need advice on final parts January 29, 2017 01:57PM |
