Bed leveling Issue - Marlin June 10, 2017 11:08AM |
//=========================================================================== //============================== Delta Settings ============================= //=========================================================================== // Enable DELTA kinematics #define DELTA // Make delta curves from many straight lines (linear interpolation). // This is a trade-off between visible corners (not enough segments) // and processor overload (too many expensive sqrt calls). #define DELTA_SEGMENTS_PER_SECOND 200 // Center-to-center distance of the holes in the diagonal push rods. #define DEFAULT_DELTA_DIAGONAL_ROD 215 // mm // Horizontal offset from middle of printer to smooth rod center. #define DELTA_SMOOTH_ROD_OFFSET 141.5 // mm //158 // Horizontal offset of the universal joints on the end effector. #define DELTA_EFFECTOR_OFFSET 21.5 // mm // Horizontal offset of the universal joints on the carriages. #define DELTA_CARRIAGE_OFFSET 12 // mm // Effective horizontal distance bridged by diagonal push rods. #define DEFAULT_DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET) //Uncomment to enable autocalibration debug messages //#define DEBUG_MESSAGES // Precision for G30 delta autocalibration function #define AUTOCALIBRATION_PRECISION 0.03 // mm // Diameter of print bed - this is used to set the distance that autocalibration probes the bed at. #define BED_DIAMETER 120 // mm // Z-Probe variables // Start and end location values are used to deploy/retract the probe (will move from start to end and back again) #define PROBING_FEEDRATE 100/10*60 // Speed for individual probe Use: G30 A F600 #define Z_PROBE_OFFSET {0, 0, 0, 0} // X, Y, Z, E distance between hotend nozzle and deployed bed leveling probe. //#define Z_PROBE_DEPLOY_START_LOCATION {20, 70, 30, 0} // X, Y, Z, E start location for z-probe deployment sequence #define Z_PROBE_DEPLOY_START_LOCATION {0, 0, 30, 0} // X, Y, Z, E start location for z-probe deployment sequence //#define Z_PROBE_DEPLOY_END_LOCATION {5, 70, 30, 0} // X, Y, Z, E end location for z-probe deployment sequence #define Z_PROBE_DEPLOY_END_LOCATION {0, 0, 30, 0} // X, Y, Z, E end location for z-probe deployment sequence #define Z_PROBE_RETRACT_START_LOCATION {0, 0, 30, 0} // X, Y, Z, E start location for z-probe retract sequence #define Z_PROBE_RETRACT_END_LOCATION {0, 0, 30, 0} // X, Y, Z, E end location for z-probe retract sequence #define AUTOLEVEL_GRID BED_DIAMETER/3 // Distance between autolevel Z probing points, should be less than print surface radius/3.
Re: Bed leveling Issue - Marlin June 10, 2017 05:05PM |
