Please help about Delta arms length and width August 20, 2017 06:45AM |
Re: Please help about Delta arms length and width August 20, 2017 04:22PM |
Re: Please help about Delta arms length and width August 20, 2017 06:19PM |
Re: Please help about Delta arms length and width August 20, 2017 07:33PM |
Re: Please help about Delta arms length and width August 21, 2017 08:11PM |
etfrench
The further apart the arms, the more rigid the machine but the print area decreases.
Re: Please help about Delta arms length and width August 22, 2017 03:39PM |
frankvdh
etfrench
I'm struggling to see how increasing arm width reduces print area... is that just due to the fact that wide arms requires a large effector, which in turn means the nozzle itself can't go near to the base of each tower? Or is there more to it than that?
Also, if you increase the arm length, you will get a larger, more triangular, print area with apexes out between the towers? But as a consequence lose some height?
So longer arms would compensate for wider apart, at the cost of some height? Whereas shorter arms, close together. would result in a rounder print area? Presumably there's some optimum ratio of arm length to arm width? And arm length is proportional to tower spacing, based on the 60/20 rule?
Re: Please help about Delta arms length and width August 23, 2017 06:39AM |
Re: Please help about Delta arms length and width August 23, 2017 10:24PM |
Re: Please help about Delta arms length and width August 25, 2017 12:30PM |
Thank you for the tips, but I couldn't visualize what you meant, sorry my bad Is there any website containing the relevant picture?Quote
etfrench
Your diagram should be a Reuleaux Triangle to be more accurate.
I'd post an image, but Photobucket is holding my photos for ransom
Basically, draw an arc from each arm on the effector when it's at 90 degrees (in front of the tower). The radius of the arc is the position of that arm on the effector when it's at the maximum extension (20 degrees). Repeat for the other arm. Locate the effector so the center of the arms is on each of those arcs. This will give you the maximum print area at the bed. It will decrease as you move off of the bed.
Note: It is possible to design a (working) delta where the angle in front of the towers is >90 degrees.
Re: Please help about Delta arms length and width August 25, 2017 08:25PM |
