TMC2130 stallguard2 as touch probe? December 09, 2017 08:48PM |
Re: TMC2130 stallguard2 as touch probe? December 10, 2017 02:51AM |
Re: TMC2130 stallguard2 as touch probe? December 10, 2017 08:58AM |
Re: TMC2130 stallguard2 as touch probe? December 20, 2017 05:27PM |
Re: TMC2130 stallguard2 as touch probe? December 20, 2017 06:04PM |
Re: TMC2130 stallguard2 as touch probe? December 20, 2017 06:05PM |
Re: TMC2130 stallguard2 as touch probe? December 21, 2017 02:02AM |
Re: TMC2130 stallguard2 as touch probe? December 21, 2017 02:43AM |
o_lampe
I tried stall detection on my compact carrier Delta with 1.7A steppers. At first I couldn't find a setting that homes well and later doesn't spit out tons of stall warnings.
I had to modify the homeDelta.g file and add a M915 line in the end to reduce sensitivity and switch filter on. Now it works reliable.
The sensitivity window is pretty small: I had a lucky punch with S5, but then tried S6 and S4 and both failed.
Re: TMC2130 stallguard2 as touch probe? December 21, 2017 11:25PM |
dc42
o_lampe
Increasing the minimum speed for stall detection (M915 H parameter) widens the window, but then of course there is a greater risk of missing stalls at low printing speeds.
Re: TMC2130 stallguard2 as touch probe? December 22, 2017 02:56AM |
The sensitivity can be set as needed during the different operations.
Re: TMC2130 stallguard2 as touch probe? December 22, 2017 03:17AM |
o_lampe
I tried to set sensitivity while I got so many warnings reported, but sending M915 Sxxx didn't work. I guess, I have to send M915 X Y Z Sxxx instead?
Or would that cause the other parameters to fall back to their default values?
