Anycubic Kossel Plus try to level outside bed area January 12, 2018 01:07PM |
Re: Anycubic Kossel Plus try to level outside bed area January 13, 2018 03:27AM |
Re: Anycubic Kossel Plus try to level outside bed area January 16, 2018 10:36AM |
Re: Anycubic Kossel Plus try to level outside bed area February 27, 2018 08:20AM |
//=========================================================================== //============================== Z-Probe Offset ============================= //=========================================================================== /** * Z Probe to nozzle (X,Y) offset, relative to (0, 0). * X and Y offsets must be integers. * * In the following example the X and Y offsets are both positive: * #define X_PROBE_OFFSET_FROM_EXTRUDER 10 * #define Y_PROBE_OFFSET_FROM_EXTRUDER 10 * * +-- BACK ---+ * | | * L | (+) P | R <-- probe (20,20) * E | | I * F | (-) N (+) | G <-- nozzle (10,10) * T | | H * | (-) | T * | | * O-- FRONT --+ * (0,0) */ #define X_PROBE_OFFSET_FROM_EXTRUDER 38 // X offset: -left +right [of the nozzle] #define Y_PROBE_OFFSET_FROM_EXTRUDER -28 // Y offset: -front +behind [the nozzle] #define Z_PROBE_OFFSET_FROM_EXTRUDER 0 //-1.3 //-4.1 // Z offset: -below +above [the nozzle] -0.5 is lower nozzle than -4.1
#define DELTA_CALIBRATION_RADIUS (DELTA_PRINTABLE_RADIUS - X_PROBE_OFFSET_FROM_EXTRUDER - 5) // mm
Re: Anycubic Kossel Plus try to level outside bed area March 01, 2018 07:41AM |
Re: Anycubic Kossel Plus try to level outside bed area March 01, 2018 07:53AM |
// The size of the print bed #define X_BED_SIZE ((DELTA_PRINTABLE_RADIUS) * 2) #define Y_BED_SIZE ((DELTA_PRINTABLE_RADIUS) * 2) // Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS -(DELTA_PRINTABLE_RADIUS) #define Y_MIN_POS -(DELTA_PRINTABLE_RADIUS) #define Z_MIN_POS 0 #define X_MAX_POS DELTA_PRINTABLE_RADIUS #define Y_MAX_POS DELTA_PRINTABLE_RADIUS #define Z_MAX_POS MANUAL_Z_HOME_POS
Re: Anycubic Kossel Plus try to level outside bed area March 01, 2018 08:00AM |
Re: Anycubic Kossel Plus try to level outside bed area March 01, 2018 08:17AM |
Re: Anycubic Kossel Plus try to level outside bed area March 01, 2018 08:27AM |
// 3 arbitrary points to probe. // A simple cross-product is used to estimate the plane of the bed. #define ABL_PROBE_PT_1_X 0 #define ABL_PROBE_PT_1_Y 75 #define ABL_PROBE_PT_2_X 65 #define ABL_PROBE_PT_2_Y -40 #define ABL_PROBE_PT_3_X -65 #define ABL_PROBE_PT_3_Y -40
