incorrect height February 05, 2018 03:41AM |
Re: incorrect height February 05, 2018 06:26AM |
Re: incorrect height February 05, 2018 09:08AM |
DjDemonD
First fine tune your extruder calibration, print objects to get the exact extrusion amount, a slightly rough top layer can add 0.3mm easily. Overextruding by a tiny amount can add 0.3mm.
DjDemonD
Once you've done that, you need to print 2 cubes but different heights.
Print 1 cube 20x20x20
Print another next to it 20x20x40
Now if they are both 0.3 too high so 20.3 and 40.3 then the issue is with first layer height/squash change settings there, check your first layer nozzle to bed gap and adjust. Could just be rough top layers...
If one is 20.3 and the other 40.6 then you have an issue with your steps/mm. Unfortunately, on a delta it's not just a case of just changing them from say 80 to 78.8 ((40/40.6)*80) although you should do this and it will help but you then need to recalibrate your machine. Use least squares method its very easy even without a probe, go to [www.escher3d.com] put in your parameters, probe the height at the points suggested, then calculate and change your values. Easy.
Re: incorrect height February 05, 2018 09:17AM |
DjDemonD
Re: incorrect height February 05, 2018 09:21AM |
Re: incorrect height February 05, 2018 09:31AM |
Re: incorrect height February 05, 2018 09:34AM |
DjDemonD
If you think about it when the effector moves up or down purely Z only, all that happens is all three motors turn by the same amount. So to position your nozzle at z=40 all 3 motors must move the carriages by 40mm exactly. However when you move in X and Y then the effect of lowering the steps/mm or increasing it will mean the movements will not be correct (not remaining within the XY plane, you'll get concave/convex motion), so you have to recalibrate once you get the steps/mm correct.
Re: incorrect height February 05, 2018 09:37AM |
DjDemonD
I haven't really time to check through it all, but if the 40mm cube is proportionally larger still than the 20mm cube change steps/mm for xyz as your have shown above:
#define DEFAULT_AXIS_STEPS_PER_UNIT { XYZ_STEPS, XYZ_STEPS, XYZ_STEPS, 95 }
then recalibrate. Seriously try the least squares you can calibrate your machine with one set of probe point heights. It amazes me that anyone would use any other method.
Re: incorrect height February 06, 2018 03:12AM |
Re: incorrect height February 06, 2018 03:47AM |
Re: incorrect height February 07, 2018 06:04AM |
Re: incorrect height February 07, 2018 06:15AM |
Re: incorrect height February 07, 2018 08:11AM |
DjDemonD
Its just a way to help calculate the correct steps/mm value. You can adjust it so if its 98 now and the objects are consistently 40/40.6 in size then do 98x(40/40.6) = 96.55 and use that value for #define XYZ_Steps
Then recalibrate and try some 20mm and 40mm tall objects again.
Re: incorrect height February 07, 2018 08:24AM |
Re: incorrect height February 08, 2018 03:05AM |
Re: incorrect height February 08, 2018 07:25AM |
